T5 2011 flashing coil light help please 🙏
  • Thread starter Thread starter kee
  • Start date Start date
kee
Hi everyone new here , hoping for alittle help and advice.
So it all began with the flashing coil light and the maintenance light with loss of power.
Diagnostic said new actuator. Had that changed. Drove home all ok. Next day , the coil light came bk on and lost power again.
I then decided to take to another garage.
Another Diagnostic turbo and EGR fault.
Had the turbo reconditioned who also tested the new actuator which was fine and new connectors pipes. Filters and oil. Lights went off happy days 🤗🤗🤗🤗
Day after came to Turn her on... SHOCK HORROR the flashing light came bk on..
Limp mode again.. turned the engine off and started her back up and the flashing coil stays off all day after multiple engine turns and the power is back fully. Until the following morning. This has happened the last 3 days.
So it's there in the am. Turn her off .restart and all is ok for the rest of the day .
Took her back to the garage and he hooked her bk up and it now shows an error with the manifold pressure sensor.
Anyone any ideas or thoughts please .
Keeley
Unfortunately when he plugged it In again he didn't give me the code 🙃🤦‍♀️😳 sorry. He just said it was showing the manifold sensor pressure error
Hope it is this. Seems a mystery. Keeo getting parts replaced and left with sane issue x
Did the EGR get replaced?
My money is on problems with that.
The EGR needed replaced on my T5.1 which gives the problems you described and after it died for the 3rd time I had it mapped out of the ecu and the vans never ran better since. That was a few years back.
Fab thanks for this I'll have a look into this there's a place close to me that does it I'll give them a call tomo. But yes he did fit a new EGR X
Hi everyone would appreciate any help or advice.
So vehicle has had a new actuator, new egr valve , new manifold air pressure sensor. And the turbo reconditioned.
Below are the code.
Yesterday I had a n75 fitted and this hasn't sorted the issue.
What next 😭😭 garages are telling ne it needs this and that i do as they say and I'm still left in the same situation 20250422_084204.jpg20250422_084204.jpg20250422_084200.jpg
Reading on the forum - and I hope this is your problem - can you check the battery voltage?
Sometimes a flat battery can give dodgy codes/faults but I don't think they are the serious ones you are getting. Worth a try - I'm crossing fingers and toes that you have a flat battery!
I've got the battery om charge as we speak. Anything at this point is worth a try so ty
Need battery hasn't worked 😭😭 worth a try.. the garage is now saying it needs a new turbo even though this one has been reconditioned and tested x
recalibrate once on the vehicle
No, assuming the actuator was correctly adjusted at the repair shop.
Code:
Turbocharger Boost Control Position Sensor Circuit - P2563 - Implausible Signal
Would have been helpful to know how the position was "implausible".
Actually the engine control unit had recorded what it was expecting and what it received when the fault happened. See an example below
Code:
16261 - Turbocharger Boost Control Position Sensor Circuit
          P2563 00 [167] - Implausible Signal
          MIL ON - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 325748 km
                    Date: 2048.01.02
                    Time: 10:09:44
                    Engine RPM: 825.75 /min
                    Normed load value: 27.8 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 22 °C
                    Intake air temperature: 18 °C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 14.640 V
                    Turbine actuator 1 bank 1: posit.feedback - Specified value: 100.00 %
                    Turbine actuator 1 bank 1: posit.feedback - Actual value: 93.29 %
                    Turbine actuator 1 bank 1: posit.feedback - Offset closed: -24.29 %
                    Turbine actuator 1 bank 1: posit.feedback - Raw voltage: 1.866 V
                    Accelerator pedal travel: raw value: 0.00 %
Code:
Code:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 325748 km
                    Date: 2048.01.02
                    Time: 10:09:44
I'm in a mess with it all and I feel like garages are just taking the mushy pea out of me cause I don't have a clue. Feel like I should of gone to vw from the offset . I'm 3000 deep and no better off 😒 anyone locally to oldham and know a decent garage to take where ill be able to see all the correct reading ti justify why the want to change parts. 4 parts changed and nothing has cured her I drive to Spain soon in her 🙃
I'm in a mess with it all and I feel like garages are just taking the mushy pea out of me cause I don't have a clue. Feel like I should have gone to vw from the offset . I'm 3000 deep and no better off 😒 anyone locally to oldham and know a decent garage to take where ill be able to see all the correct reading ti justify why the want to change parts. 4 parts changed and nothing has cured her I drive to Spain soon in her 🙃
Have you tried volksmaster?
