Hi All
I have has my 6.1 for a few weeks and just got around to doing an autoscan, the following faults came up, should I be concerned?? TIA
Address 01: Engine (J623-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 RS HW: 04L 907 445 M
Component: R4 2.0l TDI H01 9705
Revision: 23301001
Coding: 001940144344050900000000000000000000000000000000
Shop #: WSC 00012 790 00172
ASAM Dataset: EV_ECM20TDI03004L906056RS 004007
ROD: EV_ECM20TDI03004L906056LE_004.rod
VCID: 0F7BBEF387DBFDE3628-805A
VINID: 9E606AAAA1D8A9D6001C2146084081F5A1
4 Faults Found:
36567 - Cylinder 3 Pressure Sensor
P03AA 00 [096] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 20201 km
Date: 2023.01.28
Time: 17:14:32
Engine RPM: 120.50 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 58 °C
Intake air temperature: 0 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 9.953 V
Unlearning counter according OBD: 36
Air mass at air mass meter 1: 0.0 kg/h
Standardized air flow ratio: 1.000 counts
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: -0.35 %
Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
Charge air pressure: specified value: 0.000 bar
Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1019 mbar
Mean injection quantity: 0 mg/stroke
Index of current engine mode: 7
Index of next requested engine mode: 7
Index of engine target mode: 7
39804 - Cylinder 3 Pressure too Low
P03AE 00 [096] - -
39828 - Cylinder 3 Pressure Sensor
P03AC 00 [100] - Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Mileage: 20201 km
Date: 2023.01.28
Time: 17:14:35
Engine RPM: 1353.50 /min
Normed load value: 54.5 %
Vehicle speed: 17 km/h
Coolant temperature: 78 °C
Intake air temperature: 15 °C
Voltage terminal 30: 14.593 V
Unlearning counter according OBD: 40
Cylinder head: pressure sensor 3 bank 1: raw value: 145.0 bar
39827 - Cylinder 3 Pressure too High
P03AF 00 [100] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Mileage: 20201 km
Date: 2023.01.28
Time: 17:14:35
Readiness: N/A
Revision: 23301001
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 20201 km
Date: 2023.01.28
Time: 17:14:32
P03AE 00 [096] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Mileage: 20201 km
Date: 2023.01.28
Time: 17:14:35
P03AF 00 [100] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Mileage: 20201 km
Date: 2023.01.28
Time: 17:14:35
Readiness: N/A
