T6.1 Heated Steering Wheel
On dsg it’s a switch to gnd when not on P.
On P it’s floating, “not on P” it’s GND
I shorted it to gnd to verify, and I can drive without pb, no more warning while driving.
Now the problem is when I open the door !!
(Controler think I’m not on P)
If you want to do quick fix you can short to gnd, it will bell during driver door opening, but you can drive.
I will take dsg signal to send it to pin 9.
Keeping in touch.
You can try „PIN 2 „ from T2he.
You are right, on Ignition lock solenoid (N376) there is the GND signal, I will try tonight.
-steering wheel is f***ing hot :cool::cool::cool:
-no more error displayed on virtual cockpit
-heating button work well
-heating can be launch from 5F (multimedia)
but:
-I still have error in vcds log due to swing arm
-I can't add 5mph with "+" for ACC, it only add 1 by 1 (hope it can be changed by vcds)
I will make a full resume when everything will be ok.
but:
We've not saw this issue and the 5mph increase works well,
The swing arm issue will probably have to stay as it causes no visible faults on the vehicle, and the stalks running through module 16 isnt being used,
Did you get the temperature adjustment working via 5f too?
Happy to see you cracked it
Yes 3 temperature available via 5F.
It needs to be connected to pin 2 (blue/purple) on key withdrawal lock solenoid around the igntion barrell for error to stop on DSG models.
but:
What is a swing arm? The slipring :)? Did you change the stalks as well with slirping?
Let me know if you fix your cruise increments for +/-5 as mine only does one now too and I only changed my button pack
but:
If you used correct slipring you need 5Q0 953 502 M combi switch to stop errors. Otherwise the slipring is looking for it due to them being connected directly to it not like original ones are
