I have done something stupid. I omitted the relay when I fitted my PIAA 500Hz/600Hz horns and they worked fine for 6 months until i noted the horn didn't work yesterday.
I was under the impression from the wiring diagram that the horn is fed from SC36 and that this has a 30A fuse and so I simply wired in the horn without a relay as wasn't going to exceed 30A.
Today I checked the voltage at the horn and I have a static voltage of 2.6V. When I press the horn, the voltage then increases to 10.3V! I have referred back to wiring diagrams and can't for the life of me work out how I established that Fuse SC36 provides power to the horn, but is doesn't!
I'm now kicking myself for omitting the installation of a relay!
It is now pi55in6 with rain, so i have abandoned the problem but would very much welcome and assistance.
View attachment 201954View attachment 201959
I am in panic ,as fuse SC36 is intact and I now I look at the wiring diagram I am panicking as the horn cabling doesn't look to be protected from fuse SC36 or any other fuses that I can locate for that matter! I am therefore worried that the airhorns have overloaded something and melted cables or a connection somewhere. I m feeling a bit overwhelmed on where to start locating the fault! Any help from Gurus such as
@Pauly @Loz @mmi @Dellmassive would be enormously well received as I ned a pointer or two!
I assume that
@YWS22,
@Californication69 or
@VanBlanc have not experienced any issues?
