Hello.
I have been trying to find answers, but sadly none of them have been the answer my car is looking for.
After having had contaminated diesel in my car (water/bottom residue from an old tank), the car suddenly stopped running while driving.
The car has not started again since.
I flushed the tank and fuel system, filled it up with new diesel, replaced the injectors (New oem) and the filter, but no luck. The car started for a short period after the injectors were replaced, but then it turned back off.
The transferpump is work and there seems to be pressure on the system according to vcds. Tried bleeding out the system via vcds and manually bleeding out the system on the injectors.
Will run (rough idle) on startgas.
No fault codes.
T6.1 2.0 Diesel, 2021. Engine code CXHA.
No fault codes.
