Great work as ever, but talk about cutting it fineFinally got the Maxx Fan this arvo, looks like a nice bit of kit, tomorrow i cut the hole
My extra lights got lost, so Hafele are sending out some more, so ill have those tomorrow.
Insulated the roof panel and carpeted and did a test fit over the weekend, its good to go, just need the extra lights, so i can connect them all up before i install it.
Ignore the brass bolt heads in the lining, the black painted bolts will be used.
While i was waiting for the postie today, i started to run the cabin wires.
* 6 mm2 tinned for the Solar
* 1.84 mm2 for the Maxx Fan
* 1.84 mm2 for the LED Interior roof lights
* 1.13 mm2 for the LED Awning Light
* 1.13mm2 for the LED reading lights
* 25mm2 for the Earth
All the resistance levels should be under 0.10 from my calculations
I ran them all through nylon sheath to the entry in the cabin from the rear, from the roof onwards, then i ran them individually through flexible conduit and secured with zippy ties and tape.
I need to get some more black electrical tape, as i ran out and had to use red to finish the job.
Ordered the new VW interior light connections from my dealer at $6 bucks each, tried to tell me that the pins (N10335807) were around $20 each
I ordered some on eBay from China for $6 for a set of 10.
Also wanted over $100 for the black VW interior light (6Q0947291A82V), and that is each...
RRP in UK in 27 pound each
Need to get it semi finished and in a liveable state as we are heading away on Xmas eve for a road trip.
So the bed will be going back in on Saturday, hopefully some interior lights, and power for the Waeco fridge.
Thanks Andy,
It will be cutting it fine, thats the fun.
I attacked the Mid roof today, that FRP/Plastic roof is toughits 6mm thick if anyone needs this info.
No photos as i left my phone at home.
Gave up on the Jigsaw and attacked it with a bearing guide router bit, tough work and it was 33 degrees in the shed..
it was a lot hotter in the van as i was surrounded my plastic sheets to hold of the dust, the vac connected to the router didn't do a great job in stopping me and my wheelchair getting covered in router roof dust while i was routing above my head
I was going to make a spacer, but i decided to take 8mm of each side of the plastic trim with the plunge saw, as a flush fit would work after measuring up the space and measuring the mount height and rail heights.
Redrilled the side mounting holes, then my wife predrilled the Midroof for the mounting holes
Yup i left the hard part for my wife, i couldn't reach it to fix it into place, so she taped it up, prepped the mounting area with a heavy scotchbrite pad and then isopropyl and we were good to go.
I covered the mount with white Sikaflex 221 and mounted it from inside the van
Then my little very capable wife screwed it down through the hole and cleaned up the Sikaflex, then added a little more for coverage, over the mounting holes and then contoured it.
It'll be interesting to see if it lets in water, once it cures and when fan unit is installed on the mount this Friday, ill water test it
I'll look at a self levelling lapping sealant on top of the Sika if it does, but I'm keeping my fingers crossed.
Hopefully i'll get the roof lining panel up and wired up tomorrow as the remaining lights arrived late arvo
Then i should be able to fit my template rear cupboard, now i have a fixed ceiling height.
Sounds like some pretty extreme bondage you Aussies are in to!!!Yup i left the hard part for my wife, i couldn't reach it to fix it into place, so she taped it up, prepped the mounting area with a heavy scotchbrite pad and then isopropyl and we were good to go.
