Lights range control module (55 - 6R0907357C) connected to CAN bus will bring that menu straight away....
The only still missing thing is the extra menu for lights&vision. Any idea what will activate that?
Did you tick 55 in CAN gateway 19 installation list?
Hi I have a problem wiring the lights I request advice I plug 5 and 6 into the unit on the B volume anyway I do not light the LED strip the rest of the light works normally please advice me from the Czech Republic and I have T5 year 2010
google translate is your friend, Loz
All parts for my retrofit are now ordered with the exception of the plug and play looms.
Other than the looms (to keep the install as simple as possible), I am using all used/second hand parts sourced from eBay to keep costs as low as possible. I won't get the warranty on parts that I would buying brand new, but I'll take my chances and if any do fail I'll replace with brand new at that time, hopefully I won't have to replace anything.
Thanks to all contributors to this thread, but big time thanks to @Robert for getting all the information we need in one place and @Pauly for the plug and play looms (please check for my PM so I can order them).
I can't wait to get this retro fit done! I'll be hiring/borrowing VCDS and it'll be my first time, so I may need some advice, but I'll check through this thread again first because I expect the answers will already be in here.
I will do, hopefully it'll be done during my downtime over Christmas, assuming all the bits and pieces from various sellers turn up, but it might not (definitely won't) be the priority for the wife and kids, so we'll see!It would be good to know how you get on, I’m tempted to follow the same route and start collecting the parts needed.
You have to start using English mate.Může můj někdo poslat přesné schéma zapojení bez nivelace podvozku. A prosím i vaše kódování jednotky měl jsem světlomety h7a teď mám full led
Is this any help? ----> T6 LED headlight retrofit?Can my someone send the exact wiring diagram without leveling the chassis. And please also your unit coding I had h7 headlights and now I have full led
Headlight Washing InstallationAnd just in case if there is someone who wants to complete this retrofit 100% properly
Do you need new bumper?
I absolutely agree with @Pauly but I have to say that it is also possible to cut openings for new jets and mount them on you existing bumper.Do you need new bumper?
