1. Yes as per Robert’s guide
2. Only needs changing if it also has the wheel for the headlight level adjustment
Magic mine doesn’t as it’s a highline
My plan is to make my own loom using the information from @Robert in this post. I plan to start with the levelling sensors etc and then run the loom to the headlights ready. Then fit the lights & code last to reduce down time...
Exciting ...Funny you should say this, I have downloaded all the schematics from erWin!
I have a cheeky trick up my sleeve to save on labour time and parts costs... all I will say for now is kufatech Xenon harness.....
Watch this space...
Yes it’s possible if you are resourceful with a bit of reutilisation of cables, 56 and 28 can double (same as if you have barn doors)Funny you should say this, I have downloaded all the schematics from erWin!
Watch this space...
Did you check these codings --> T6 LED headlight retrofitOld coding:
A0A4303A4A73343193284F746CEB8E750F84708F60CC6D70320400220840
It's a selectable function. With your old coding - no, doesn't dim. Byte 23, bit 7.Should DRL dim when indicating ?
Did you check these codings --> T6 LED headlight retrofit?
Could you please post your current coding?
I’ve got everything brand new (except for the range control unit) and its coming in at £1800 inc vat!! More than I was hoping to spend but I suspect if you waited you could save a bit more? The headlamps themselves are expensive and the levellers but as I figured these were the bits you’d see and or likely to wear so I wanted new. However the ballast packs on eBay aren’t much more new over used.
My advice would be to get a list of prices from VW as a start point (just make sure you’re sitting down when you do!!) and then work from there, BTW some things on eBay were more expensive than from VW. Then shop around and source the bits form where you can. I think if you waited and went used you could do this for the £1000-£1100 that others have.Thanks Paul, that's very helpful.
Not too bad really tho for headlights of that standard I feel.
Listing some info for when I do my retrofit on WednesdayAre you installing the levelling system ?
Pins 1/2/3/4 are for range control/servomotor so if you are not doing the levelling these will be unused
I dont have all the pinouts to hand for the LED looms that i make but the list above does not look correct, for example pin 8 takes a 12v feed (originally pin 1 on H4 headlights) and this does nothing, there isnt even a connection in pin 8 on the back of the headlight but you list it as highbeam and say the headlights are working ?
Im confused ?
