T6 virtual cluster from aliexpress
BigYoeKing
Czech member
Hi i just want to show virtual cluster for vw t6. the wait was long , but today it arrived from china.
the original cluster must be disassembled and the motherboard from it used for the new ones. installation is quite simple, although a bit rough.
I had to cut out a piece of plastic because of the connector, but otherwise it fits. the oil temperature shows bad otherwise everything else works
That is awesome! I will buy one of those for sure once there is a none Chinese version that works.
Mat
View attachment 259706View attachment 259707
Did they do this for PQ25? Do you have a link to the product? Are the turn signals and light indicators working?
Yes for pq25 in t6. With turn singnals and indicstors I had a problem, but I upgraded in the menu and then it works, I hope it will in the future.
buying here, good seller, even though I pestered him for 2 months, when will they be available.
Just found this amazing item on AliExpress. Check it out! US $675.18 | Wowuseful 10.25 Lcd Digital Dashboard Cluster For VW Variant Caddy Touran T6 EOS Sharan Golf 5 Virtual Instrument Paneel Cockpit
They look amazing.
That’s right down my street but I would be worried about the mileage display.
Would be too easy for someone to think you’ve fitted them and whooped off 100k miles at the same time.
