Grant Hume
Hi All, I live in Sydney Northshore area and am after an expert infotainment installer for Golf vehicles. Could you please point me in the right direction?
Thanks. I did read something similar to this after I wrote my comment so I edited it. But thanks for answering my question regardless.As far as i know, in QLD, AWD is the same as 4WD, so it is 50mm max including tyre and suspension lift (EDIT: has changed)
Im running 225/65R17 with a 30mm Seikel lift kit
It is worth looking at the latest QLD Transport modification guidelines.
https://www.publications.qld.gov.au...nal.pdf?ETag=9b9838a666de1d95a4c34d3e6e94d2e6
Page 3 at the bottom.
4WD type, AWD is a 4WD type
Also, you need to look at your ADR category is, mine is NA
So looking at that document you are allowed up to a 75mm lift from standard by having a max 50mm lift suspension and 25mm lift through tyres & wheels.As far as i know, in QLD, AWD is the same as 4WD, so it is 50mm max including tyre and suspension lift (EDIT: has changed)
So I believe a 50mm change in tyre diameter is the max I can have legally.
Ok so going to 235/70R16 from a 205/65R16 would be a 62mm change in Diameter or 31mm lift which would be over the legal limit.
Your 225/65R17 from 205/65R16 is a 51mm change or 25.5mm lift which I suppose would be acceptable as half a mm could be negated in tread wear alone.
Edit* though not all transporters come with 205/65R16. So I suppose if you had the 17" wheel combination from stock it opens up more possible tyre sizes.... maybe
Does your wheel and Tyre combination still fit in the spare tyre carrier under the vehicle?I worked off the 50 mm O/A rule for both that was in place at the time.
My Transporter that i ordered new came with 215/60R17 from Factory, so with the new tyres i got a 17.25mm height gain.
does your tyre card decal have the 17 inch option on it? if so then you can use that as your base
