Oh, I assumed that the remote sent a signal to some central receiver, which told the various locks to open or close. Does this mean that the external tailgate switch has it's own receiver?I assume the fact that the key remote tailgate opening didn't work points to the switch is the tailgate handle?
Hi @Pauly, I am thinking of a temporary fix for my problem (it's incredibly inconvenient having to crawl through the dog caging to open the tailgateThe internal and external button utilise the same two wires in the tailgate, theres a negative to one side of the switch then either switch contact simply switches this negative signal and sends it out on the same piece of wire to tell the door to open
If one switch is working then the overall wiring is ok and it can only be an issue with the switch itself or the wiring in the bottom of the tailgate where the handle is (approx 2 foot long)
I would drop your internal tailgate panel of and get access to the external switch wires, its a two pin blue connector with two white wires in it, if you unplug and short out the two pins in the blue connector this will let you know if the issue is with the switch or the wiring - assuming the door opens then the issue is with the switch but remember to start simple, it could simply be that the switch is not connected or plug not pushed fully home
Oh! @Pauly Briefly pressing the internal switch on the tailgate is not enough - the tailgate unlatches, but only moves a short distance, unless it is pushed open quickly it stops there and can't be opened further.Hi @Pauly, I am thinking of a temporary fix for my problem (it's incredibly inconvenient having to crawl through the dog caging to open the tailgate). I will join a pair of wires to the pins or wires on either the internal or external switches, run the wires through a small hole in the internal panel, take it under my dog caging to a switch accessible from the sliding door (ideally a push button switch but otherwise any switch which you have to turn briefly on then off). ...
Thanks for your suggestions.Why dont you just fix the external handle ?
Think i would just use a piece of wood to push the tailgate from the side door area until the rear handle is fixed
That's normal - or mine is the same, I need to press and keep the switch pressed as long as the tailgate has passed both latches.Briefly pressing the internal switch on the tailgate is not enough - the tailgate unlatches, but only moves a short distance, unless it is pushed open quickly it stops there and can't be opened further.
(1) Is this normal behaviour? [I guess anyone with a T6 Kombi with a tailgate with an internal switch to open the tailgate could answer this.]
Yes, no problem with that - for a few minutes at least.(2) Would it be OK to close my temporary switch and leave it closed while I walk round and pull the tailgate open, then go back round to the sliding door and open the switch? Might something burn out?
Thanks very much @mmi, I will go ahead with my temporary fix. Though I am temporarily stuck at the bottom of my track, because of snow and ice. We don't have proper winter tyres here in North Scotland (I used to work for a company based in Helsinki, I was very impressed the way everyone drove around at high speed on the snow in winter, while we were all getting stuck in England at the slightest bit of snow.)That's normal - or mine is the same, I need to press and keep the switch pressed as long as the tailgate has passed both latches.
Oh, it doesn't work quite as I thought. I attached wires to the plug, with a switch to short the wires together. Closing the switch opens the tailgate, but even if I keep the switch closed the latch times out and closes before I have time to walk from the sliding door to the back of the van! So now I have a longer pair of wires, and I pull them out and walk round to the back of the van with the switch. Remote control, just not wireless remote controlThanks very much @mmi, I will go ahead with my temporary fix.
Well, to take it to the next level - would a foamy pad (squeezed by the closed tailgate) push the tailgate past the second latch at one go?the latch times out before you open the tailgate
Thanks for the suggestion, not sure if a foamy pad would move it enough but well worth a try.Well, to take it to the next level - would a foamy pad (squeezed by the closed tailgate) push the tailgate past the second latch at one go?
In the document "T6 Fuse Layout SC,SD,SF.pdf" there are various fuses mentioned for the rear lid control unit, e.g. see below, that is for No. 8021 21, there is different information for No. 8021 23, etc, and I don't know which applies to which vehicle, or even if it's the control unit that is not working in your case.I have similar problems.
The rear tailgate latch was opening itself and eventually stopped working. I changed the solenoid still not working. Doesn't seem like any power going to door handle at all now.
I can't seem to find a fuse for it also.
I too have dog cages in the back and also having to climb through a cage to get to mechanical lever
