I keep reading all these threads about rattles, and creaks, and stuff going wrong, and my van is still perfect.
That makes me nervous...
No it wasn't. It was the tailgate. I've wound the Nobby out as far as I think it'll go. I now just get a little pip squek over speed bumps. Is it worth adding a little vaseline to the seals?It was the jack all along.
The striker plate is done up very tight. I don't want the tool to slip or round the bolts. I'll get the stealership to take a look at the next service.You could try adjusting the striker plate on the bottom in a couple mm then readjust the bump stops to fit ??
Mine did too, then had a new seat base and it stopped. 2 months later it's back. And I'm back to the warranty department!My drivers seat creaks on corners and before you ask no I’m not a fat b*****d![]()
Hihere you goView attachment 16572
