Progress on the same bit above, it's now almost done.
The 2 ducts in place, with one going to the front of the unit, in between the fridge and the back of the drivers seat, leading to a vent on the front.
I'll have storage to the right of the vent, big enough for cans of food. Then another shelf above the ducting, as it'll be capped off on top.
This bit of the unit is by far the most complex, once this is done I should be able to race through the rest!
The cut out on the left side is for the seatbase plugs, I'll be running a connector through this to a fusebox in the unit for the fridge, lights, water pump and some usb ports.
I've got a day off work tomorrow so will continue with this, should be able to get this section fully completed.
