That max height is still pretty low. @Tourershine is in that territory and has had those widths... again a slimmer tyre thoughBeing on max height, there’s no way it’ll go lower without modification / tyre change that’s for sure!
You’ll be fine.. it will be tight but I’m sure it will work. No pain no gain!! Bin those arch liners or let them rub throughGoing to be interesting & tight one too call. I was considering the projekt lows just so I could go up incase. But I can always drop a tyre size like you say depending on the outcome. Not taken a look the arch properly yet but I'm sure there's room to found somewhere. Will keep it updated as I learn
Exactly, I've ran some pretty extreme wheels in the past and just heated arch liners up etc. So it's not something I'm afraid ofYou’ll be fine.. it will be tight but I’m sure it will work. No pain no gain!! Bin those arch liners or let them rub through![]()
That’s what I like to hear!! Failing that you could always try a 235/30Exactly, I've ran some pretty extreme wheels in the past and just heated arch liners up etc. So it's not something I'm afraid of
So approximately how low is Max height on the SoLows?Being on max height, there’s no way it’ll go lower without modification / tyre change that’s for sure!
100mmSo approximately how low is Max height on the SoLows?
Looks sweet at 90mm @N G NeerFinally got round to fitting these. Specs are: Front 8.5, Rear 9, BMW Ferric grey with 255/45/18 all round. Lowered 90mm on Twin Monotube Projekt coilovers. Excuse the dirty van.
Cheers. I think another 10mm or so would be spot on but I'm happy enough with it. Nice comfy ride and practical as a daily driver.Looks sweet at 90mm @N G Neer![]()
@matt_r I fitted mine and no clearance or rubbing issues. As others have said I think your issue was a combination of door cards, tyre size and ride height.
I think 80mm would do the job.Yours looks amazing..
I've got the same tyres as you, but feel I definitely need to go lower, I think I can only go 80mm max on my set up @T6ARF might be able to confirm as he has the same set up.
If you got some machined front top mounts and rear adjuster delete you can get another 15mm down if you want to.Yours looks amazing..
Yeah I’m sure when I had my H&R/Koni setup fitted @CRS Performance, Steve said with the delete kit on the rear, it would go down another 15mm.... so 80mm altogether. I’m sure @ChrisR can confirm if I’ve got that right?Yours looks amazing..
I run Koni/H&R coilovers on my own van with machined front top mounts and rear adjuster deletes. That = approx 95mm drop front and 90mm rear on my van. Results vary depending on the weight of the van, especially on the rear.Yeah I’m sure when I had my H&R/Koni setup fitted @CRS Performance, Steve said with the delete kit on the rear, it would go down another 15mm.... so 80mm altogether. I’m sure @ChrisR can confirm if I’ve got that right?
What colour is your van again??Just ordered my 19s for mid jan Just have to decide on colour tho.
