Yes, you could fit larger profile (percentage of the width) tyres if fitting smaller diameter wheels.Ok, folks, thicky newbie here: learning a lot, but getting more baffled. Now understand that the smaller number on the tyre's sidewall (40/45 or whatever) is the ratio of sidewall to width ( I think) but 16 to 20 something is the wheel diameter is it, or not? My Fiesta has 205/40/17s, but the wheel measures 18.5 edge to edge
When gearing is discussed, do you learned folk mean that as long as I keep the wheel plus sidewall radius the same, gearing is unaffected, ie I could drop to eg 15s and have larger sidewall off road style tyre's?
Use an online calculator to determine how a new set up compares with your existing tyre sizes.
Example calculator here>>> Will They Fit - Online Wheel and Tyre Fitment Calculator
Input your existing tyre size in box on left and new size on box on right and hit 'calculate'. This will then give both values for circumferance, speedo error etc and give you an idea whether you are increasing or decreasing overall diameter.
Thank you for your reply, presumably you are "allowed " a percentage error on the speedo....on a level road my speedometer might read 60, the sat nav 63.Yes, you could fit larger profile (percentage of the width) tyres if fitting smaller diameter wheels.
If you get to a hundred, you'll have far bigger problems than points - more like a ban for gross excessive speed eh @Thogg!I can't remember the exact persentage but you would be boarder line with your reading under but it can read over a lot more . The kit cars I build have to be tested on a rolling road so always set them reading fast. The persentage will go up as you go faster so at 100 mph it could be 6 or 7 out but by then you are getting point any way.
Yep... tonight's night shift consists of doing the paperwork for someone who saw fit to do 112 mph when the outside temp on Dartmoor was -4 and everything was frozen solid and white! His wheels were standard though!If you get to a hundred, you'll have far bigger problems than points - more like a ban for gross excessive speed eh @Thogg!
Oh my...Yep... tonight's night shift consists of doing the paperwork for someone who saw fit to do 112 mph when the outside temp on Dartmoor was -4 and everything was frozen solid and white! His wheels were standard though!
Book him Dano.Yep... tonight's night shift consists of doing the paperwork for someone who saw fit to do 112 mph when the outside temp on Dartmoor was -4 and everything was frozen solid and white! His wheels were standard though!
