We used to use it on our fishing equipment,before modern textiles negated it's use.
If I remember rightly...we srayed it on with an atomizer,and then rubbed it in with a cloth.
Hi Carl, you may already received and applied the stuff but it went on easy.
just pour some into a separate container and apply with a brush, work your way along the canvas in the same direction maintaining the wet edge to prevent streaks.
Im away in the van as we speak - had a storm last night and got the inevitable seeping at the seem where the fly mesh meets the zip. Will try and source some seem sealer and report back!
how did you get on using FABSIL gold. I know it was a long time ago but I am thinking of using the spray can version on the outside of my poptop canvas
Cover the van on the top edge as best you can for drips brush on with new 4inch paint brush as you do a section it’s important to rub in lightly with a cloth so there are no brush lines only do the once the silicone makes fabric slightly tougher and you don’t want it too stiff when it folds away hope that helps should take only one hour to do
