Thanks Miken, did you do anything with the main beams or are they still the original halogens ?
I would not recommend HID in main beam, if you have main and dipped stay on at the same time, that's a lot of heat in a plastic lamp casing, would you agree dubber?
The reason I wouldn't fit HIDs in main beam would be the slow warm up time. When you switch to main beam, you want/need full power straight away.
With regards to HIDs creating more heat, halogen bulbs get far too hot to touch, so it's not something I'd given much thought to. I'd always considered the airflow from the movement of the vehicle to give sufficient cooling to the headlights.
I’ve been reading the last few pages of this thread and I feel that the more I read, the more confused I am!
What I am after is brighter headlights to my stock T6 headlamps, I am not particularly bothered by the fancy indicators, I don’t have access to VCDS to reprogram and I don’t feel confident enough to be removing any bodywork. Could anyone advice what my options are for straight forward swap outs?
thanks,
Ambrose
4300K HIDs arrived this morning. Fitted them in no time (I'm getting to be a dab hand at this job) turned them on...WOW. Even in daylight, just WOW against the garage door. Started the van... flicker, flicker, turn off. Turn off the engine, ignition back on, WOW, there we go...start the engine, yes you've guessed it.
There is something overly fussy about our vans. When they had turned themselves off, there was no power going to the headlight plug, so it's not a fault with the HIDs. Even with bulb monitoring turned off, if it senses something is different, it's not happy.
Update:
Just spoken to the suppliers and they say that 55W kits will not work with our vans. The one I should have bought, and that I will be exchanging it for is H7 Terminator 35w HID XENON CONVERSION KIT CANBUS ERROR FREE
Look forward to this!!Apparently my Novsight canbus add on boxes have arrived so it'll be interesting to see if they stop the flicker on my H4 Novsight "Godzilla Mutilator" LEDs... everything is crossed as the lamps are great in our other car.
Regarding the flicker is it caused by the lamp out detection signal as it's superimposed on top of the normal light output and not a PWM issue with the H4 being pulsed to dim... could just be VW sour grapes?
Sounds good, we can have a bulb off on Sunday!Won't be until Friday at the earliest mate as it's freezing,too dark and I'm an old man with backache, OTOH I could have them in on the Sunday afternoon meet if these bits of kit work.
If they don't work you'll have to put up with the £19.99 Lumen Blaster v. 0.5 which even though I do knock them were brighter than the poor sod in the stock H4 T6 we went past on the A34 last Friday going down to Bournemouth... sadly however, nowhere near as bright as the Volvo XC90s we were slip streaming later.
