Trolley Jack -
T6180
T6 Legend
What weight and brand trolley jacks are people using for there T32s?
I've started to do a lot of motorway miles and didn't want to be stuck on the side of the road for to long messing with the factory jack.
Plus you have to use a jack to keep swapping over your wheel collection.
I do :whistle::laugh: Halfords 2 ton low profile. £40 :thumbsup:
Will the low profile reach high enough to get the wheels off the floor? I was thinking I'd have to buy 2 new jack's but I already have 2 of them?
2T should be enough when you look at what the maximum axle load is for your model and then bear in mind you are only lifting around half of that weight as the opposite wheel will be on the ground. I went for 3T though for piece of mind
I use a 2 Ton Halfords jack - and a rubber pad with a groove in it to locate where the standard jack goes.
I have the 3t Halfords before they discontinued it. Where did you get your rubber pad with groove in from ?
