Turn off rain sensor for auto wipers
Hi all, Is it possible to turn off the rain sensor to the wipers
You can adjust the sensitivity with the toggle on the top of the wiper stalk. It won't completely turn off the auto function, but does help to find the sweet spot.
Yes, very annoying!
Depending on which version you have, you should be able to switch individual functions and systems on and off in the vehicle settings of the Infotainment system.
  1. Switch on the ignition.
  2. Switch on Infotainment system if necessary.
  3. Depending on the version, press the menu button or function button, select the Vehicle menu and tap the settings gearwheel icon.
  4. Tap the corresponding function buttons to open additional submenus in the Vehicle settings menu or to make settings in the menu options.
  5. Tap the return arrow button to go back to the previous menu.
The respective function is switched on if the checkbox in the function button is ticked.
I have a 17 plate and can`t use the radio version to change functions as mine is on the dash board.
