Great thanks.It's a doddle! Take your time and don't force anything - if it doesn't just pop off don't force it (that's how I break things...!)
Some good pics come with it and there's an install video floating around on their website.
They do fit with the lane guidance/sign recognition camera. They sent me the wrong housing - correct one is now being posted foc.I really like the idea but I've got the lane guidance/sign recognition camera as well and not sure from the pictures of that's an option for the 6.1?
Is this because you don't have a rain sensor ? just wondering why you've had to hard wire it to leisure batteryManaged to complete mine now, ran the hardwire kit down to the leisure battery (passenger side) there is just enough cable in the kit.
I made up a loom to take the engine run feed from the standard leisure battery relay and fed that into a delay relay to provide the ignition feed.
Ah I see , I did see it had parking mode didn't know you had to order extra cablesBecause I want to use the parking mode on the highly sensitive setting, it also often sits for quite some time, so I try and keep as much as possible away from the main battery. BTW it works really well a light tap on the windows is all it takes to start recording.
I also prefer to keep any 3rd party electrics away from the factory wiring, nothing wrong with using them it’s just a personal preference and as I needed to route the rear camera cable decided I may as well do the power cables at the same time.
It also means I have 2 x new fuses in the factory fuse box under the passenger seat specifically for the dash camera.
Looks like on their diagrams that you do get all the cables and it looks like you have to use the hardwired cables if you want parking mode. I'll check when it arrivesI think it would also work off the rain sensor as that provides both feed’s![]()
That's odd why is yours white the one I ordered for my t6.1 has a black casing.Fitted mine now with the correct housing to the rain sensor using there splitter loom. However I now have a message “automatic headlamp fault” Indeed the auto headlamp function has stopped working. I have unplugged the camera and the auto headlamp works again. I’m thinking a hard wire would be a better plan. Has anyone used their hardwire kit? Where is the closest switched live?
Mines all blackIs your trim around the mirror black or off white? I sent a pic them of my trim and then ordered. Initially they sent completely the wrong housing and eventually the correct one came which I then had to swap over the internals.
I’m thinking just to go hard wired maybe to the interior light pod where I hope to find switched live.
