I have not unboxed the aerial yet but heard good reviews about netvoxThanks just found both on eBay . Have u wired it all up yet is it a clear enough picture with the arial..... thanks
@Phil_G Just found your post and the info TV aerials. I am looking a VFM and a good returns policy in case it doesn't work - so Argos and John Lewis are top of my list!!! We are going to give it a try and see how we get on! Only ever going to be used with a hook up. Just checked your recommended AUGUST DTA245 and LOOKS GOOD! Appreicate we have moved on and wondered if you still would recommend this one? Paul. ps is that you on the bike - just sold mine :-(Depends what you mean by good Paul!
A good size? good gain? good directional selectivity? good F/B ratio? good value? Good returns policy?![]()
Its an unfortunate fact that any TV aerial small enough to be convenient in a van is going to be relatively poor when
compared to the yagi on your house roof
The 'Status' range are not bad for a permanent installation, but most are omnidirectional which is convenient but not optimal.
They do cased directional ones too but they're quite a bit bigger and need to rotate.
If you're prepared to use a pole, a small yagi (say 5 ele upwards) should perform reasonably well. Pretty much all 'indoor' aerials are poor.
The August DTA245 is probably as good as a small indoor aerial gets, its amplified (USB powered) and has a magnetic base, so
unless its raining, you can stick it on the roof where at least it has a decent ground-plane
Most tellys now have a usb port which you can use to power it.
Most campsites are out in the sticks so the signal is often poor, so have some DVDs ripped to a memory stick for backup!
Phil
Thanks. Any particular model you went with?I still rate very highly the Necvox mag mount one.
I use a cello 22 inch and the necvox ,never had a problem connecting the Arial up . Al try and have a look behind mine to see the space I have but all seams fine on mineJust got the Necvox ANT-536 aerial, but when I tried to fit it to the Cello 16” tv in our new campervan there is not enough room to connect it to the tv aerial socket with the adaptor fitted, due to the shape of the back of the tv - there is a vented moulding right below in the way. Don’t all aerials use a similar adaptor? Any advice greatly appreciated.
Quality @Phil_G ... too scared to take my Fazer on the track!!! Loved that bike- should never have sold it.
Quite right on all counts about the TV and the rain ... thanks coming back soo quick
August DTA245
