Tyre pressures 255/35/20
Can anyone please tell me what the tyre pressure should be for Pirelli 225/35 r20 97y. I believe they should be 42 psi front and 43 psi back?? Many thanks in advance
What weight rating is your van T28, T30 or T32?
What width are the wheels you have?
I put 39psi in mine as tyre says no more than 40psi. I’ve just changed mine to 255/40/20 not sure what to put in them when I need to next?
check this web page out, there are instructions on the page.
Good luck
Hi, I’m looking to get optimum tyre pressure for my T28 with 255/35ZR20 102W XLs on it. It’s used as a camper and I bought it with the tyres set at 52PSI, which seems a little high. I’ve taken them down to 46PSI but would appreciate any pointers. Thanks.
I'm using 255/40 on a camper, running at 36-37PSI. I tried it at 38 but was getting some tyre centre wear.
P.S. 52!!!! WOW!
I’m running 255/35/20 102 on 20x9s. Says the max pressure is 50. I run then at 45psi at the moment as any less and the front wheels just looked a bit low. 1000 miles in and seems ok so far
