It's a 97w I thinkWhat is the load rating of your tyre?
The closer your axel weight gets to the load rating of the tyre, the more pressure you need.
Often the markings on the side of the tyre, mention max load at max pressure.
But so long as that is OK, I would have thought 42psi ish would be a good starting point
Have you ever been on a weigh bridge in fully loaded trim, so see what your actual weights are? I would have thought a T28 is probably getting close to its max axel weight, especially on the rear axel, so your tyres are probably at their maximum load, or even over.
Just be careful; and run your tyres at a higher pressure, probably over 50psi, check the side walls for info.
The mode for most tyre failure which is not ware or damage related is overheating.
As i understand it, If a tyre is run with too much load; too fast; to too lowly inflated, or a combination; the heat builds up quickly in the tyre and boooooooom!!!!!!!! failure. A bit dramatic but worth thinking about.
I have done it with a caravan on more than one occasion, good tyres, just overloaded.
I'll check tomorrow cheersShould be 99 for a T28 according to Tamar Wheels.
Thanks - interesting! What load rating is on your tyres (or have you changed from standard 16")?
I will check the load rating. It they arre standard from the factory.Thanks - interesting! What load rating is on your tyres (or have you changed from standard 16")?
Any idea about the standard 205/65 16"? I have gone to recommended but 60psi just seems a ridiculously high pressure??We recommend running 275/35 20's at 40 psi all round. I run this on mine, even with heavy loads and towing with no uneven tyre wear
I guess you are very close to the tyres maximum load. Most tyres have to be run at maximum pressure to achieve maximum load. The down side is that everything about a tyre is worse at that kind of pressure.(other than economy) I am carrying a similar load to you on 235/60/17 and running safely at around 40psi. I would strongly recommend changing to 17" wheels and tyres (235mm wide) when you can. There are loads of Devonport vw t6 wheels and tyres around (brand new-delivery miles) for around £600, which is an absolute bargin. It also relates to the tyre pressure = the ground pressure which equates to the load you are carrying; so narrower tyres need greater pressureAny idea about the standard 205/65 16"? I have gone to recommended but 60psi just seems a ridiculously high pressure??
Tyres are at pressure recommended on sticker - just feels wrong - after pumping up and wanting to double check I dug my old faithful gauge out but found it only went upto 50psi.The tyre pressures are on a sticker on the drivers B pillar. Im not in a T6 this weekend so cant check.
