I might be able to find you one of those. I know I have chucked a great many of them in the bin, when we cram in plenty of other stuff under the seat, they have to go!
If you do have, Martyn, I’ll send you some cash to cover P&PI might be able to find you one of those. I know I have chucked a great many of them in the bin, when we cram in plenty of other stuff under the seat, they have to go!
My shuttle has two 15A fuses there as well and the towbar electrics got added to that fuse block so I'd guess any kind of rear body accessories.No, i've tested all 12V sockets in the van and nothing. My two dash 12V sockets are in the fusebox under the dash (blade fuse and block fuse). I've seen a fuse layout diagram for a cali where the rear 12V sockets are split (copied below). The left one in my image in the thread above supplies both rear sockets on the C pillar and next to the rear heater in the wheel arch. In the diagram below that's the fuse that's labeled '12V Sink''. From what i've seen I get the impression VW just use this fuel block for 'extras' that are ordered with the van and most usually in this location means it's something in the rear. I have a climate control panel in the rear roof so maybe it's that? However I only see 15 AMpfuses being used for 12V power sockets so i'm completely stumped.
@JB26413 Agreed.... i've just fitted my tow electrics and was going to wire it into power in this fuse box too. I accidentally cut the wrong wire from the bundle of red 12V permanent lives for it though, and cut the one to the supplying the blue fuse i'm trying to find out about. Even though it's got no power I can't find anything 'not working'My shuttle has two 15A fuses there as well and the towbar electrics got added to that fuse block so I'd guess any kind of rear body accessories.
Ah well, not needed then@JB26413 Agreed.... i've just fitted my tow electrics and was going to wire it into power in this fuse box too. I accidentally cut the wrong wire from the bundle of red 12V permanent lives for it though, and cut the one to the supplying the blue fuse i'm trying to find out about. Even though it's got no power I can't find anything 'not working'
knowing my luck it'll be the brake lights or somethingAh well, not needed then
That is only valid if you have a California as there is a socket next to the sink.In the diagram below that's the fuse that's labeled '12V Sink'
As far as i'm aware both rear 12V sockets run off the same single 15Amp fuse. I tested the sockets with a multimeter to see what was going on, removing each one of the blue fuse in turn. However thinking about it little, all the other 12V sockets (2 in the dash) are on separate 15 Amp fuses Should each one have it's own fuse? Sounds like i've cocked up my testing or somethings up with the wiring and the circuits are joined together.12V socket on right D-pillar?
Ah perfect , sounds like if I rewire them both to go via the leisure battery fuse box then I’ll be fine. Thanks for the help everyone.My Shuttle has two 15A fuses under the seat, the front fuse is for the 12v outlet by the C pillar, the back 15A fuse does the 12v outlet in the boot by the air blower unit.
@mmi @Pauly apologies both, I know this is an old post but did you find what the part numbers are for the 3 fuse clip in fuse holders are? also the larger single fuse holders bottom right? Many thanks in advance, NickIf only few fuses need to be relocated, another OEM solution:
Clips into the main frame and each socket houses 3 fuses. Sorry, don't have part numbers for the socket or crimp fuse connectors. Interested to know though.
No worries, thanks for the quick replyno, sorry
