Here is a situation to digest. Couple of days ago I get a low voltage VRM alert. I have the bmv set at 12,6v low voltage alert. The battery was 70% plus SOC, and no loads, apart from the propex gas heater set to frost protect 2deg. If that kicks in, it draws 30w no surge. It’s just a fan and a ignition for gas. When I went in the van, the voltage showing 13,2v, but, there is always a difference between vrm voltage and bmv actual voltage in the van. The bmv is 0,1-0,15v lower most of the time. What am I missing? After last alert, I have plugged the van on ehu, and charged to 100%SOC, you can see the amps climb to 75 ish. That’s the ehu charging.
