Use an iron remover / cleaner
And a wheel sealant
And a wheel sealant
Gyeon offer a very effective bug remover.Really impressed by autoglym super resin polish, my bonnet is the worst panel on my van, it's got everything - chips, scratches, bird poo etching, dull spots, etched on water marks, you name it, it's got it! Oh and it's black.
SRP made an easily noticeable difference to the depth of shine and gloss, and hid a good amount of the light swirls, and lessened the deeper swirls.
Anyway, I now need a solution to dealing with bugs on the windscreen while on a 3 week road trip. I'm heading down to the south of france/northern space so there's bound to be some proper bugs being splattered against my windscreen, I'm thinking a basic window cleaner with sponge and squeegee, and some proper bug remover, should do the trick without needing a rinse off/full wash?
Yeah now the van has had a coat of SRP (it had nothing before) I'll just use wet coat on each wash while it's still wet, should make it much easier to clean and dry each time.I'm a big fan of Geyon Wet coat spray on a panel wash off with a power washer and job done. Gives great protection over the winter months and cuts down in time
I won't be doing any coating like that until my paint is corrected, it's in a pretty bad way with swirls/scratches etc. - not sure I'd want to seal those inI have a dedicated car dryer and it worth it weight in gold. The less contact you get with paint the better.
If you using wet coat have you used geyon can coat evo2? It an easy to use ceramic coating that will give you 6 months protection on one application. I then use the wet coat as a top up. Brings up a car a treat and does not need the whole prep work like a top end ceramic coating
Ah fair enough if you going that far in getting a 2 stage then I'd recommend a full ceramic coating then. I've done them on all my cars and saves a shed load of time when washing especially in summer months with the direct sunlight. Adams do a very very good shampoo that works well in the summer heat and I use it all the timeI won't be doing any coating like that until my paint is corrected, it's in a pretty bad way with swirls/scratches etc. - not sure I'd want to seal those in
I'll hopefully get it booked in for a 2 stage correction and ceramic coat over winter.
Just looked at the Geon can coat and it does look good, but the van can't get wet for 12hrs after application, my van lives outside and I just know it'd rain if I even tried something like this!Ah fair enough if you going that far in getting a 2 stage then I'd recommend a full ceramic coating then. I've done them on all my cars and saves a shed load of time when washing especially in summer months with the direct sunlight. Adams do a very very good shampoo that works well in the summer heat and I use it all the time
If you struggling for time another quick way to wash the van I use in winter is use a snow foam. This can also be used in the summer monthsJust looked at the Geon can coat and it does look good, but the van can't get wet for 12hrs after application, my van lives outside and I just know it'd rain if I even tried something like this!
Yeah it needs a full going over with a polisher, and that's exactly why I want a full ceramic coating, being black it's almost impossible to wash in summer, meaning it gets left for 2 months at a time between washes, and even when I only do a few hundred miles it's filthy with dust and stuff from sitting on the drive. If I can smash out a full wash in 2hrs rather than 4hrs I'll wash it more often!
Unfortunately I use a portable worx power washer which isn't really powerful enough for a proper snow foam - I might try one of the new electric foamers tbh as they seem really good at producing thick foam. My foam doesn't really last more than a minute!If you struggling for time another quick way to wash the van I use in winter is use a snow foam. This can also be used in the summer months
I apply one to loosen all dirt power wash off. Then use a second coat with a good microfiber wash pad and two buckets and wash with the snow foam on. This gives good protection and lubrication preventing swirl marks etc
What foam are you using and what PIR are you at. The power of the washer should not hugely matter.Unfortunately I use a portable worx power washer which isn't really powerful enough for a proper snow foam - I might try one of the new electric foamers tbh as they seem really good at producing thick foam. My foam doesn't really last more than a minute!
