From the factory T6 Webasto aux/parking (water) heater comes configured to heat cabin only.
Up here in Finland the vans come with overhead control/timer panel to allow the use of timer or remote to switch on engine and cabin preheating before setting off. The heater is configured by dealer to heat both engine and cabin.
The trick that makes the heater to warm both engine and cabin is to configure the coolant change-over valve as "not installed". See coding screenshots below.
In this configuration the flow of coolant will be as shown in the picture below. Always through both cabin heat exchanger and engine block. (The factory path shaded out).
Cabin air blower will start when coolant temperature at heater has reached +45C (value controlled by adaptation channel). At outdoor temp -20C it takes about 8 mins, at -5C about 5 mins. At that point engine coolant has reached temperature of about +25C.
Some related information in threads:
Webasto Overhead Control Panel.
Webasto Auxiliary Heater - customizing
Webasto Thermo & Comfort Se
Error code aux. Heater carista
PS. In late MY18 (recently delivered) vans the low voltage cut-out configuration has been changed, see picture below. The both vans from where the codings (above and below) were grabbed have second battery from factory under left seat.
PS 2. Does anyone know access code for adaptations? The controller accepts code 20103 but it still doesn't allow me to tweak adaptation channels. Not that there is any need to change anything, just don't like the idea not having all the controls .
EDIT: PS 3. Some of the adaptations need the code above, and then some accept 80782 so "problem" solved.
EDIT: Link added --> https://cardiagn.com/volkswagen-transporter-2016-2020-workshop-manuals-wiring-diagrams/
When configured cabin only (factory setup), cabin air blower starts at about 3 mins. I did verify that the heater obviously never switches to heat the engine. I tested that a few times at outdoor temperature -5C and when checked after 30 mins there definitely was no engine warming in 30 mins (engine coolant was still below 0C).
EDIT: The reason for coding change of low voltage cut-out is that from Nov-2017 onwards the Webasto is powered from starter battery. See attachment.
Fault codes:
VCDS And Carista Fault Codes
Address 08: Auto HVAC (J255) 9480753 - Control/Display Unit for Rear Climatronic B10AA 31 [008] - No Signal Not much information available for this; it would seem to be a temporary communication loss with the rear climatronic unit.
www.t6forum.com
Retrofitting Auxiliary heater to Parking heater:
OEM Webasto Auxiliary Heater To Parking Heater Upgrade
All required components are already purchased, tested and ready for the installation. Well invested €58=£49 :thumbsup: My ODIS-E is also ready to upload new(better) firmware ;)
www.t6forum.com
In my panel there is only two symbols: either ventilation (blower only as in the linked picture) or cabin heating (heater symbol). The engine heating is not indicated any way in the panel. Does this make sense? Perhaps you could post a picture of your manual and symbols of the control panel...
www.t6forum.com
Remote sync/learning:
1. Verify the remote: press OFF ▷ blinking red light on the remote.
2. Power OFF the controller (5Q0963513A or 3Q0963513) for at least 5 seconds. OEM setup fuse SC54 (7.5A)
3. Power ON the controller.
4. After approx. 2 seconds (but before 6 secs) press OFF on the remote for 1 second.
5. Verify by pressing OFF again ▷ steady red light on the remote (instead of blinking).
Remote sync/learning using VCDS
2. VCDS ▷ Select ▷ 18-Aux. Heat ▷ Basic Settings ▷ IDE06650 Adapt wireless transmitter IDE06650 ▷ [Go]
3. Press OFF on the remote for 1 second ▷ [Stop]
4. Verify by pressing OFF again ▷ steady red light on the remote (instead of blinking).
Heater unlocking:
VCDS ▷ Select Control Module ▷ 18-Aux.Heater ▷ Basic Settings ▷ IDE06654-Disengaging/Unlock heater
The fault code will stay in memory - can be cleared if so desired.
OBDeleven ▷ Control Units ▷ 18 Parking Heater ▷ Basic Settings ▷ Disengaging heater
