No, Ross-Tech tools do not allow flashing of modules - but definitely is the must have diagnostic tool for VW owner.Will this Ross Tech work for flashing?
VCP is one of the tools that can flash modules:
Hello again.@ZimaSpartan before you flash your heater, get the Multicontrol hooked up and see how it works without flashing.
Do you have someone who can flash the heater for you? Obd11 won't be of much help if you intend to keep your T6 for some time...
Keep us posted on the results.
I have just the manual found here: https://www.lvparts.lv/files/downlo..._D_Aufrüstung_2020_TT-Evo(OE)_Kit_1328073.pdfHello again.
I tested today.
I hooked up Multicontrol and it is not working.
The display powers on and all the parameters can be selected. When I quick start or select start heater via timer I can hear a click from the vehicle. Sounds like a clicking relay and green light on control is glowing but heater is not starting. After few seconds green light goes off. No errors on multicontrol or in OBDII.
On live data on OBD i found lines saying that outside temp is over limit (outside temp was 6 deg. celsius) and that parking heater not active or supported (cant remember and I forgot to take a screen shoot).
The engine was warm cause I just came from work, is it possible that this could be the problem?
Any ideas?
Thank you...
Looks like webasto added an extra control unit (which they call Cronus)...I have just the manual found here: https://www.lvparts.lv/files/download/?type=SP&id=76&name=1328074A_EN_VW_T6.1_D_Aufrüstung_2020_TT-Evo(OE)_Kit_1328073.pdf
I had doors opened and climatronics temp not set to 20 deg. Do you think that is the problem... but i think heater should work anyway. Maybe just blower does not work when not set probably... any ideas...
I guess i should try once more...
@eugene I found data about Coronus which is some sort of CAN-bus interface more like the DANHAG but with much more work around dash and with heater flashing. At this moment I think that DANHAG is a better solution since it is a plug&play module on 17p connector under seat and as I can understand there is no need to flash heater and no additional wires to Climatronic in opposite to Climate where additional loom is needed. Can anyone confirm this? And price for Cronus with flashing is higher...Looks like webasto added an extra control unit (which they call Cronus)...
I am sure it can be done simpler but little experience and absence of a real T6.1 to experiment do not allow me to give advice here...
Bonjour j'ai installé le kit telstar t100Assurez-vous d'avoir éteint avec la télécommande avant de tenter à nouveau le démarrage. (Sur mon T100 si je démarre avec la télécommande je dois alors éteindre avec la télécommande plutôt qu'avec n'importe quel autre contrôleur sinon la télécommande continue dans le mode de la dernière commande)
Pour démarrer, appuyez et maintenez jusqu'à ce que le voyant fixe s'éteigne, cela vous indique que le radiateur a reçu la commande. Une fois le chauffage en marche, le voyant doit clignoter jusqu'à ce qu'il soit éteint.
(Je préfère le T100 car vous avez alors un écran LCD sur la télécommande avec les informations allumées.)
Hi. Did you get around to installing it?@eugene I found data about Coronus which is some sort of CAN-bus interface more like the DANHAG but with much more work around dash and with heater flashing. At this moment I think that DANHAG is a better solution since it is a plug&play module on 17p connector under seat and as I can understand there is no need to flash heater and no additional wires to Climatronic in opposite to Climate where additional loom is needed. Can anyone confirm this? And price for Cronus with flashing is higher...
Hi mmi. Do you know if the scan above is from a car with the remote control or just the overhead panel?Well, this thread is all about heater modification on T6 (PQ25 platform) - yours is T6.1 (MQB platform) which means that the all the controllers are different. This modification on T6.1 has not yet been done AFAIK.
Anyways, on T6.1 the desired functionality (OEM remote) as from factory has the following identifiers:
Address 18: Aux. Heat (J364)
Part No SW: 5WA 963 272 A HW: 5WA 963 272 A
Component: STH-VW37x 006 0010
Coding: 3543223854121512DCE519
Note: a different software than on T6.
Not 100% sure anymore - as I don't have access to that van anymore. Anyways, the software is the "nordic" one - with preheat capability.Hi mmi. Do you know if the scan above is from a car with the remote control or just the overhead panel?Code:------------------------------------------------------------------------------- Address 18: Aux. Heat (J364) Labels:* None Part No SW: 5WA 963 272 A HW: 5WA 963 272 A Component: STH-VW37x 006 0010 Coding: 3543222054121512DCE519 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_AuxilHeateWOSVW38X 001009 ROD: EV_AuxilHeateWOSVW38X_VW27.rod Remote Control Auxiliary Heater: No fault code found. -------------------------------------------------------------------------------
I really hope it's got the remote installed as well.
Just trying to help others on T6.1.
Part No SW: 5WA 963 272 C HW: 5WA 963 272 C
Component: STH-VW37x 006 0012
ASAM Dataset: EV_AuxilHeateWOSVW38X 002009
ROD: EV_AuxilHeateWOSVW38X_002.rod
Auxiliary heating remote control:
Now I am confused. Both of the scans mention Remote Control. But the software is different.Not 100% sure anymore - as I don't have access to that van anymore. Anyways, the software is the "nordic" one - with preheat capability.
So what exactly is your concern? Coding or software?
This below MY22 T6.1 obviously has - a mention in VCDS Auto-Scan:
Code:------------------------------------------------------------------------------- Address 18: Aux. Heat (J364) Labels:* None Part No SW: 5WA 963 272 C HW: 5WA 963 272 C Component: STH-VW37x 006 0012 Coding: 3543223854121512DCE519 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_AuxilHeateWOSVW38X 002009 ROD: EV_AuxilHeateWOSVW38X_002.rod Auxiliary heating remote control: No fault code found. -------------------------------------------------------------------------------
Also a MY20 T6.1
The latter grabbed fromCode:------------------------------------------------------------------------------- Address 18: Aux. Heat (J364) Labels:* None Part No SW: 5WA 963 272 A HW: 5WA 963 272 A Component: STH-VW37x 006 0010 Coding: 3543222054121512DCE519 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_AuxilHeateWOSVW38X 001009 ROD: EV_AuxilHeateWOSVW38X_VW27.rod Remote Control Auxiliary Heater: No fault code found. -------------------------------------------------------------------------------
VW T6.1 Transporter ROD Files missing
Hello currently have latest version of ross-tech 19.6.2 running on a 2020 VW T6.1 Transporter. It says some ROD files are missing. I have downloaded the latest beta files that VCDS can find but still no luck. Wednesday,19,February,2020,12:36:52:53429 VCDS -- Windows Based VAG/VAS Emulator...forums.ross-tech.com
Well, it looks like there is possibly a change in production thus suffix change from A to C (around MY21). However, it's just my feeling based on few scans I have managed to collect.Now I am confused. Both of the scans mention Remote Control. But the software is different.
In first example it is: 5WA 963 272 C
In the second example (like in the Nordic setup van that you posted): 5WA 963 272 A
Likely both 5WA 963 272 A and 5WA 963 272 C.1. What software is installed on a T6.1 van with the telestart remote present? So far it seems, 5WA 963 272 A is the software with the telestart (and overhead remote). But I need a confirmation of this.
Note: Variants 5WA 963 272 and 5WA 963 272 B seem to reside with petrol engines.
Not exactly. The remote receiver connects only to heater controller - no CANbus connection - thus not really related to PQ- or MQB-platform.2. The telestart recievers used in this thread (3Q0963513) are designed for MQB cars (LIN connection). Does T6.1 need flashing at all? (since it's an MQB)
Thanks mmi!Well, it looks like there is possibly a change in production thus suffix change from A to C (around MY21). However, it's just my feeling based on few scans I have managed to collect.
Code:Note: Variants 5WA 963 272 and 5WA 963 272 B seem to reside with petrol engines.
Heaters sold further south in Europe seem to have installed software: 5WA 963 271 A or 5WA 963 271 C. Again transition at/around MY21.
Address 18: Aux. Heat (J364) Labels:* Redir Fail!
Part No SW: 5WA 963 271 C HW: 5WA 963 271 C
Serial number: 000000000000313
Coding: 3543221854121512DCE519
ROD: EV_AuxilHeateWOSVW38X_002_VN3S.rod
VCID: 4CC0630AE64978AAF3B-8018
Coding: 3143221854121512DCE519
Hi. First question - did you reflash the heater? Different flash file needs to be used for T6.1. Flash from T6 won't work.Hi,
I'm trying to get my remote control to work on my 23 (MY22) Caravelle.
Followed the YT video that Eugene made.
Bought the controller (3Q0963513) and a remote (3G0963511) wired it all up, and with vcds i changed the coding so it 'knows' there is a remote.
So far, so good.. but it doesnt seem to work.
Sometimes when i hold the 'on' button on the remote, i hear some clicking under the van. On the climatronic unit the lights of the temperature turn on (no actual temp is showing) and the blower starts blowing on the auto-mode. After a few seconds, it stops.
Other-times it doesn't stop, but only blows cold air. The weird thing is that i cannot turn the fan off with the remote. (On my old traded-in T5.1 i could turn it off with the t91 webasto remote)
I've read most of the topics on this forum about the Webasto heater, the only thing I cannot do in basic settings is IDE06654 - unlock heater.
It says: Not Running.
Here is the scan:
The original code was:
I was hoping that i didn't have to flash my heater, but maybe thats the problem?
Thanks in advance!
No, I did not. I only have a Hex-V2 pro cable..Hi. First question - did you reflash the heater? Different flash file needs to be used for T6.1. Flash from T6 won't work.
See message 533 from @mmi above and compare this to the part number from your scan and I think you will know the answer what should be the next stepNo, I did not. I only have a Hex-V2 pro cable..
On your video, someone responded that the heater in his T6.1 didn't need flashing.
Also, I thought I read in one of the topics that after MY21, the heaters came with updated firmware.
To be honest, thats why i kinda hoped it wasn't needed.
Ah that makes sense now, I think I misread, so for my understanding: the difference between no telestart and telestart is 271 vs 272?See message 533 from @mmi above and compare this to the part number from your scan and I think you will know the answer what should be the next step![]()
Yes. Did you manage to do it?Ah that makes sense now, I think I misread, so for my understanding: the difference between no telestart and telestart is 271 vs 272?
So i need to flash the 5WA 963 272 A file?
