Webasto Auxiliary Heater - customizing
Hi,
yesterday I tested Telestart module 3Q0963513 with VW T6 and it works properly, so if someone needs module paired with remote control transmitter tested with VW T6 Webasto Auxiliary Heater I have one (50Euro + shipping)
View attachment 61741 View attachment 61742
To use an existing auxiliary heater as parking heater you need:
  • Auxiliary Heater 7E0963273A
  • firmware FL_7E0963272B__0009.frf
  • vas5054A and ODIS or VCP
  • Telestart with LIN [ 5Q0 963 513 A, 3Q0963513 (new remote) ]
  • new coding in Address 18: Aux. Heat (J364) Labels:| 7E0-963-27X-18.c Coding: 5001 <- new coding (old was 4101)
That's all.
Buenos días, tengo una vw t6 2016 con thermo top evo adicional para calentar el motor en temperaturas bajas.
Le e puesto un multicontrol( mando) e intentado configurarlo con el OBD, pero me dicen de la marca que e de actualizar el webasto en un taller oficial webasto.
Cómo lo has echo para que funcione?
Good morning, I have a 2016 VW T6 with an additional Thermo Top Evo to warm up the engine in low temperatures.
I have installed a multicontrol (remote control) and tried to configure it with the OBD, but the brand tells me that I have to update the webasto in an official webasto workshop.
How did you make it work?
This won't work. T6 Evo is using Lin bus.
You either reflash the Evo with wbus firmware (like was instructed) or install original vw overhead control panel.
IIf you reflash, you will need a different Telestart unit and a different remote control (non-vw).
Hello guys...
My aux heater update on T6.1 was on hold for a while... :)
I am still trying to figure out what to do. I did a little research and here I have a question:
If I fit original overhead display unit 7LA907049G, do I have to code or flash anything or it will work out of the box?
Is wiring already present at overhead trim?
THX!
Zima
Hello guys...
THX!
Zima
VW don't put any additional wiring in .so no wires in console.
Just get one of the kits ,they come with timer or phone app ,
Hello guys...
THX!
Zima
To be able to complete the Telestart install on T6.1 you will need:
1. TS receiver
2. TS remote
3. [not mandatory] The upgraded overhead remote control as you pointed out.
Yes, coding of the overhead panel is required.
Also, a reflash is needed, 5WA963272C is the right sw. 5WA963272A might not work. I currently only have 5WA963272A, still looking for 5WA963272C.
The telestart unit is wired like in T6.
The professional retrofit guys are telling me that they can do it without the overhead display unit. BUT I don't yet know how to make it happen.
I am looking for a T6.1 where this was done successfuly so that we can all see how it's been coded.
If you don't have an overhead unit already, you will need to guide the new wiring there.
There are no vw kits available (I do have a spare Telestart kit though).
The only plug-n-play kit is the one from DanHag.
1. TS receiver
2. TS remote
So no shortcuts even with OEM overhead display unit. :rolleyes:
THX for help.
I guess I will finally end up with DANHAG...
THX for help.
There's a shortcut, unfortunately not yet publicly shared
So yes, Danhag is probably the best way for a person who is not willing to go into the detail and fuss
Just to derail a bit, is it possible with some wizzardry to activate heated mirrors when webasto is started? After following this guide i added telestart and added the wire needed to get the interior fan going when the coolant temp reaches 60c as i coded it with vcds.
