Is it the switched AUX live for things like caravan fridge? There is usually a secondary wiring kit to install this.
Is that the white and black connectors underneath?Have you tapped into the BCM yet? That was an ‘interesting’ task!
Thank you for this informationJust dug out my instructions and on the last page you’ll find ref to plug 3. Its pin 10 & 11 (not 12 as stated above)
ah yes, I have done that, absolute nightmare, like you said, right up underneath, to the point I struggled getting the cloth cable tie off one of the looms and managed to cut through 4 wires!! Then even more problems trying to get a crisper in there then to in line crimp them again! The guide said 3 hours for all the wiring. They are having a laughStep 35 to 43 in the pictoral instructions. You have to unplug the two big bunches of wires going into the BCM, find/extricate some connectors / wires and insert connectors from the tow loom and reconnect the original connectors into plugs on the tow loom. All underneath the steering column!
The pictures don’t do it justice - very over simplified. Just take your time.
pin 10 is an ignition controlled live intended for running a caravan fridge when the vehicle is running. Even when connected, it has to be activated via VCDS or similar software (or at least mine did) I use pin 10 for charging a second battery in my boat trailer.Just dug out my instructions and on the last page you’ll find ref to plug 3. Its pin 10 & 11 (not 12 as stated above)
