I got my case from amazon,It’s well worth it as it keeps it all safe and tidy
Got a Noco today. Worked out at £123 with the trade card at Halfords and a work discount on gift vouchers.
Annoyingly, they didn’t have any hard cases in stock.
No real reason apart from providing some spare capacity. I’ve seen some good reviews of the smaller ones and they seem to hold up to the punishment.These look useful to have on board the van . any reason you went for the 2000a over the cheaper 1000a ??
Is that jack to lift your van?
Put wheels on like you said they catch on full lock gutted, they were supposed to be same size as what i took off, will have to do till fronts need changing then think ill go 255/45Yes, had to go with a 255 tyre due to the wider wheel and caravelle door cards. Plus they are direct fit,load rated and use the standard bolts.
Yea could try that ill see how it goes, offset must be slightly diffIf you have a heat gun you might be able to heat up and re form the arch liners enough to stop the rubbing
Yeah only just to remove the wheels to cleanIs that jack to lift your van?
Are you going to convert this one?Bought myself another T6 !
Are you going to convert this one?![]()
I've had a look at all the components and they look good to me, no paint chips, everything looks straight where it ought to be.Looks like the trip to Italy was a rough one , check the contents and make sure all well please Luke
