I used a 1/4 watt 510 ohm resistor and a 3mm super bright blue LED.@Spaghetti - What size are the resistors?
Great progress @Samro...nothing like stripping something apart when it's only a few days old and everything is clean and comes apart nicely.!Good progress being made on the DIY electrics install.
Should get solar panel in tomorrow and seat bases finished off so that the converters can crack on with the sound deadening, insulation, carpet lining and fitting of 1+1+1 seats!
Not long now until I can say I am a proper T6 owner!
This morning:
Most of day seemed to be working out where everything will go!
Lots to do tomorrow, but all good!
@Spaghetti - Thanks for the response. I will order some.
Miles better! How?Cleaned up the cluster a little, not perfect but far better than it was
I’m looking for a van at the moment if you do decide to sell.That's weird. I've just driven home in a PV courtesy van from Vertu Hereford and it has the same crazing on the lower half of the clocks. I reckon it's down to alcohol wipes, but it's odd that there is a defined line half way up. They are under strict instructions not to go anywhere near my van with any sort of cleaning product.
All that might not matter tho', as I've asked them to give me a valuation to buy it. Just an option, but now might be the best time to get out of it whilst the going is so
I used some mezerna medium polish as the plastic polish wasn't doing anything. With a soft handheld padMiles better! How?
It was so bad but I know the plastic is so soft, it even marks with microfiber cloths if they aren't plushThat's weird. I've just driven home in a PV courtesy van from Vertu Hereford and it has the same crazing on the lower half of the clocks. I reckon it's down to alcohol wipes, but it's odd that there is a defined line half way up. They are under strict instructions not to go anywhere near my van with any sort of cleaning product.
All that might not matter tho', as I've asked them to give me a valuation to buy it. Just an option, but now might be the best time to get out of it whilst the going is so good.
@david173 - The Van x top glove box comes with a cut out to fit the the usb hidden by the trims. The glove box also comes with a blank that fits where the usb is in the dash. Easy job to relocate the dash usb into the Van X glovebox and then fit the blank.Ah thats good then i have been eyeing up this trim set, thanks.
I know, I sent the top dash cover back as i wasnt happy with the fit, they advised they are looking to change the design. I suggested a flush fit one like the comfort dash so we shall see!
Thanks for the info, much appreciated@david173 - The Van x top glove box comes with a cut out to fit the the usb hidden by the trims. The glove box also comes with a blank that fits where the usb is in the dash. Easy job to relocate the dash usb into the Van X glovebox and then fit the blank.
I got them from the forum shop before it closed down. Maybe @Pauly could help with manufacturer details. They are very bright so I’d recommend a dimmer if used inside the van but perfect for tailgate lighting. I’ve wired them to the leisure battery setup.@Westy78 - I like the tailgate lights, are they LED? Do you have a link for them? Where did you take the power supply from?
The fun begins!!!
