New leisure battery for the old gel
https://www.t6forum.com/threads/deaky’s-kombi-to-camper-journey.4662/page-25#post-510009
Hi I’m currently going to fit a Rib Altair 130cm slider in my swb Kombi , when fitting is it position the frame and drill holes does anything have to be removed underneath ?Fitted Altro floor, drilled several holes through the floor without killing anything, then bolted in an RIB 130 slider. Replaced Kombi card panels with carpeted ply panels. After many hours of prep, today has been satisfyingly transformational.
Next task is identify the very annoying rattle.........
Did that van have a welding torch in the back and 10000 rounds of ammo?Washed it before taking it into the dealers (only I wash my van) for the front doors bowden cable replacement safety recall. I thought I was being bold with my front grille red stripe, but then saw this new Sportline A-Team edition while I was there. Each to their ownShout out to Listers Coventry, good service
Then sorted out my camping gear ready for a quick 2 nighter down Oxford way tomorrow for a spot of paddle-boarding with the boy…
Bugger, you beat me to it fool. I'll just have to put all the bling back in the safe now.Not sure mate but the driver did say he “ain’t gettin’ on no plane”, and his passenger mentioned he “loves it when a plan comes together”.
Many bullets were fired, but miraculously no one was hit![]()
Crazy Fool.Not sure mate but the driver did say he “ain’t gettin’ on no plane”, and his passenger mentioned he “loves it when a plan comes together”.
If you’d off left your skiddies off you wouldn’t of needed the axe handle!Got up at 0400, ran out in my skiddies with an axe handle to investigate why my vans alarm was going off.
Just a moth, that’s enough to trigger the cab alarm apparently.
I’ve done that before with neighbours trying to wake me up throwing stones on my roof, still unforgiven.If you’d off left your skiddies off you wouldn’t of needed the axe handle!
Need to drop the spare wheel. It may depend on the fittings you use. I used the kit from Clearcut Conversions and used their guideHi I’m currently going to fit a Rib Altair 130cm slider in my swb Kombi , when fitting is it position the frame and drill holes does anything have to be removed underneath ?
They look greatPicked our van up from our converters after having new sliding windows fitted in the front quarters to replace the standard leakyVW windows. They have also adjusted and realigned the pop top as one hinge was not in line and the whole roof sat over to the drivers side rather than centrally.
The new windows fit differently so the sliding door window leaves a little more frame showing. The passenger side the converters have filled in around the frame and carpeted to make that look finished as it was before.
Happy days! No more leaky windows, no swimming pool in the kiravans door store pockets! I can carpet the door store now. Roll on our trip to the Ply Guys and then the autumn gathering on our way home.
