I've done some digging on here and seems others have experienced the same thing. All correct load ratings so i'm not concernedIn my experience, many tyre fitters don’t understand the technical side of what they do.
Equally there are many good ones.
Pete
thanks, came out at -0.07% difference! guess they were chatting the you know what@david173. There's a website that often been mentioned on here (can't remember the name) where you can input different tyre sizes and it will tell you the effect on the speedo.
Because he was driving it at the time? I’d find it scary if I saw the van I was driving in my rear view mirror!!!Why?
I've got rugs for bugs over factory carpet. I found it moved around, so I fitted some OEM clips to fit onto the factory pegs. Once you have worked out where the clips need to be, a pound coin is the same size and the holes you need to cut.A simple addition today of floor mat and door liners from Rugs for Bugs.
View attachment 178305View attachment 178306
What an absolute load of rubbish from the tyre fitters (jobs worth)!Fitted 4 new Michelin Cross Climate 2, 235/55/R17 103Y XL on to my Devonports. Got them from black circles at £138 a corner fitted at my local shop.
Warning rant below:
However, I had a massive lecture from the fitters for several reasons,
1) because they were different size to the original continental 215/60/R17s on there, however 235/55/R17 is a also a VW size for that exact alloy, its even on the door sticker!
2) apparent the new size would throw the speedo out, the abs wouldn't like it and the ACC radar would need re calibration??
3) They are car tyres not van tyres, even though they are correctly load rated for my T30. I even called Michelin technical before I ordered to ask what the difference was between the Agilis Cross Climate vs Cross Climate 2, obviously the Agilis is rated 109 vs 103 but both sufficient for T30. All they could advise was one was for van and other for cars however if the load rating is sufficient surely this is the important bit?? The Agillis has added kerbing protection etc and I get it if your running a large crafter or somthing similar but the tyre doesn't know what its attached to, and you why would one be fine for a 3 ton Range Rover but not for a 3 ton van??
Am I missing something here???
anyway pictures here, because we all like pictures. (excuse the dirty van, shameful I know)
Presumably your previous tires were 107 rating? Do you find them more comfortable?Fitted 4 new Michelin Cross Climate 2, 235/55/R17 103Y XL on to my Devonports. Got them from black circles at £138 a corner fitted at my local shop.
Warning rant below:
Fantastic tyres…. good size and I’m sure you wouldn’t ever know any difference…. 0.25mm on the diameter…. come on!?
I bet you’ll notice the positive difference with the comfort? Good purchase that man @david173![]()
Thank you.Presumably your previous tires were 107 rating? Do you find them more comfortable?
Cheers for the tip. Will see how I get on. Seemed a decent fit from the off but time will tell.I've got rugs for bugs over factory carpet. I found it moved around, so I fitted some OEM clips to fit onto the factory pegs. Once you have worked out where the clips need to be, a pound coin is the same size and the holes you need to cut.
