Nae bad, pal!Nae it’s nae private![]()
It’s the reply followed by chance when anyone asks to borrow itNae bad, pal!![]()
I have a different make to you (wolfbox) but it'll likely have been the same innards etc. Hoping yours works a treat. I bought cheap so it's my fault heheYes its T6, No cant say it does, I will sort a picture out tomorrow have you got the v5pro model also?
Are you using the original cable? My CarPlay screen would reboot when stop/start kicked in and I eventually found out that it was the Amazon bought USB cable I was using. I tried a different cable and it now works fine. Maybe worth trying some different cables.I have a different make to you (wolfbox) but it'll likely have been the same innards etc. Hoping yours works a treat. I bought cheap so it's my fault hehe
I used a hardwire kit from amazon that was faulty initially, then went to halfords to buy one of their kits and that worked. But I have this issue. I assumed it was to do with the start stop being mapped out however, since driving the van over the past few months it seems start/stop is no longer mapped out fully - works intermittently and hence my issue. I have gone directly through an empty central switched live slot as no matter what I connected to it wouldn't work properly.Are you using the original cable? My CarPlay screen would reboot when stop/start kicked in and I eventually found out that it was the Amazon bought USB cable I was using. I tried a different cable and it now works fine. Maybe worth trying some different cables.
Or try different slots in the fuse box. Rather than using a piggyback style fuse adapter you can get single breakout fuses (pic below) and use it in a blank slot that has the live busbar visible (if you have any). This may be more stable power-wise than a piggyback type.
Straight forward? Mine arrived yesterday
don’t forget to remove the existing trim panels - they look like they fit without removing them but they don’t.Straight forward? Mine arrived yesterday
The plywood trim?don’t forget to remove the existing trim panels - they look like they fit without removing them but they don’t.
Thank you for the tip!it’s the thin plastic trim along the top of the sliding window I did take it off could take pic when home
That sits bloody lovely!Spent a metric f*** ton of money on it!![]()
@CRS Performance for:
Koni Special shocks
Std height springs
25mm lift spacers
Lower front arm bushes
H&R anti roll bars
New drop links
Rear discs and pads
Alignment
And then onto flatdog UK for roof rack fitting, already paid for.
Result:
Suspension is massively improved, it's settled over normal 'smooth' roads, I'm not feeling every single bloody imperfection in the road and it's just a whole load more comfortable!
And it's about 4" higher than it was before!
The rack is excellent, really good mounting system and there's very, very little wind noise - if any.
