Hello, we are the newbees and would like to clarify if we should just buy a 25m hookup cable for camp sites or 10m and 15m is a better idea? If the latter, can they just be used plugged in together working as extention?Recommended is 1 each of 15m and 10m making a total of 25m. Gives you the flexibility to use either individually or as a combo of 25mts.
Enjoy the van!
Personally having a 10m and a 15m cable is more flexible and yes you can just plug them together however not if you use Caravan and Motor Home sites as they don’t allow it. Very rarely will you need a full 25 m length cable on most sitesHello, we are the newbees and would like to clarify if we should just buy a 25m hookup cable for camp sites or 10m and 15m is a better idea? If the latter, can they just be used plugged in together working as extention?
We would be very grateful for your reply.
Thank you. If you don’t mind - what the difference when using a hookup cable on Caravan and Motor Home sites?Personally having a 10m and a 15m cable is more flexible and yes you can just plug them together however not if you use Caravan and Motor Home sites as they don’t allow it. Very rarely will you need a full 25 m length cable on most sites
It’s just their rules, they have some really nice sites but lots of rules on what you can and cannot do. I guess they perceive a risk where the cables join but personally I can’t see any risk if you have proper connectorsThank you. If you don’t mind - what the difference when using a hookup cable on Caravan and Motor Home sites?
Thank you very much for your advice.If you are going to use Caravan Club sites, then 25m. See here:
What Have You Bought Today?
The good old days Yeah, nowadays he just twatters on about farming. :(:sleep:www.t6forum.com
Any extra can just be coiled (loosely) under the van.
And welcome to the forum!
Thank you very much for that. We’d have never thought of it!Don't forget to add random bits of black electrical tape at various points along the cable, makes it look old and battered and less likely to get nicked if you do leave it on site while you're out in the van.
I use an upturned (clean but they don’t know that) toilet bucket over the end. I do it as I don’t like leaving the plug out in the weather but I guess it has the same effect.Don't forget to add random bits of black electrical tape at various points along the cable, makes it look old and battered and less likely to get nicked if you do leave it on site while you're out in the van.
You could probably tour the Isle of Skye without disconnecting that from you hookup pointSorry, reaping up an old subject.
My van came with an approx 40m 2.5mm 16A cable.
Is this safe? Or should I cut it down to 25m?
TIA
Nothing wrong with it per se, but it will be cumbersome. If it really is 2.5mm & not 1.5mm (1.5mm is rated to 16A, 2.5mm is around 25A) then it will be a fair old lump @40m. As Dell says, chop it down & make up 2 different sizes.Sorry, reaping up an old subject.
TIA
Yes deffo 2.5mm took off one end and checked with a micrometer. 2.7mm inc insulation.Nothing wrong with it per se, but it will be cumbersome. If it really is 2.5mm & not 1.5mm (1.5mm is rated to 16A, 2.5mm is around 25A) then it will be a fair old lump @40m. As Dell says, chop it down & make up 2 different sizes.
For future reference, cable size is given in mm2 I.e. square millimetres, not diameter. At 2.7mm dia, your cable is (1.35x1.35)x3.142=5.726mm2 including insulationYes deffo 2.5mm took off one end and checked with a micrometer. 2.7mm inc insulation.
There is also a 15m hookup, a UK 13A spur & I assume a euro 2 pin spur.
I was more worried about the voltage drop off over 40m, but I suppose if people join 25m & 15m, it's no different.
Thank you everyone for putting my mind at rest.
