Yesterday
Done the inside of the wheel arches,
and had some thermo liner left over so used it up to help cut down on the roads noise
You did silentcoat on the arch and dodo on the liner? Space wasnt an issue?
Yeah but you need to start with a clean vanUse silent coat externally under the plastic liner is how we do it and recommend View attachment 65374 View attachment 65376
Just done my front arches this morning. Not a lot you can do, mostly they're adjacent to the engine bay (so no point) or suspension is in the way.How much silent coat is required to do the two rear wheel arches?
Haven't seen anyone post about doing the front arches - can't do or no benefit?
Most people do the front arches inside.How much silent coat is required to do the two rear wheel arches?
I did my rear outer arches last week. The great thing about doing outside is that it doesn't need to be super neat as there is plenty of space for overlapping joints. If I remember (it's been a long week) I used about 2 1/2 sheets per side but I didnt extend quite as far as some have done. 3 would definitely be enough. These were 375 x 250 mm sheets from a bulk pack of 40.
I want as much sound proofing as possible so I covered the inside arch with 6mm dodo mat. The rest of the inside is 12mm.
Thanks. Will see if I can find anyone with a volume pack of 3mm silent coat in stock.
