Bedding behind rock n' roll, Mr Smith (Bassett hound) has to sit on the front bench seat thus cannot put single passenger seat in. Smith likes to spot the burger vans enrouteOur layout is a little different to most people's. We have a permanent bed/seating area set up Taking up the rear 1.2n of the van. So out bedding stays on filled with cushions etc. Mabel (the dog) has the remaining 1m to herself. Often she will jump up on the bed area and ride there. I do worry about an emergency stop as 30kg of greyhound flying round is unlikely to be good for me or her.
Any tips or advice on the dog front would be appreciated by me as well. I was thinking of building a cage beneath a worktop area in the front.
Edit: Friend of mine has a more standard layout and keeps the bedding beneath the rock and roll bed at the rear. Seems there's quite a bit of storage there.
Hmm, car harness sounds good. Although I don't have accessible seatbelt fixing points in the back anymore. Might have to reinstate something.My Weimaraner equally weighs 30kg, but he has a car harness that passes around his neck and chest, loops round his front legs and buckles along his back. From this I have a couple of pieces, one that can fit into a seatbelt clasp, or one that has a karibener style end that snaps onto anything else in the van. Stops him flying around.
It also stops him from scrabbling out from his sleeping place under the kombi bed via the rear side door footwell, under the folded down kombi seats, through the walk between the front seats, and making himself comfy on the drivers seat. Big git woke me up twice doing this last time out until I put him in the harness and tethered him to the bed leg.My Weimaraner equally weighs 30kg, but he has a car harness that passes around his neck and chest, loops round his front legs and buckles along his back. From this I have a couple of pieces, one that can fit into a seatbelt clasp, or one that has a karibener style end that snaps onto anything else in the van. Stops him flying around.
I'll have a look and see if I can find a make of the one we have.Hmm, car harness sounds good. Although I don't have accessible seatbelt fixing points in the back anymore. Might have to reinstate something.
Would you recommend any brand in particular for the car harness?
Just a suggestion, what about a climbing grade of carabiner to latch into a load lashing point if you have them? As for harness try the Julius K9.Hmm, car harness sounds good. Although I don't have accessible seatbelt fixing points in the back anymore. Might have to reinstate something.
Yes that could work. I did remove the load lashing points when having the flooring and carpeting done but wouldn't be too hard to put one back in for this.Just a suggestion, what about a climbing grade of carabiner to latch into a load lashing point if you have them?
How big is your dog TeresaE?Hi
We have just purchased our T6 van and getting ready to go away this weekend. Where do you all pack the bedding? We were thing of storing them behind the rock and roll bed.
Also whilst travelling, where do peeps dogs travel in transit?
Many thanks
T
@ausyray, sorry but after my original post I added a recommendation for the Julius K9 harness available online but I would go to a pet store so that you can test fit to your dog and get the right size.Yes that could work. I did remove the load lashing points when having the flooring and carpeting done but wouldn't be too hard to put one back in for this.
That's ok. I spotted it. Just googled it, I was hoping her current ruffwear webmaster might do the trick. They look fairly similar (although the webmaster isn't crash tested) and it seems like it provides enough support. If I can get the load lashing point sorted again I think I have a winning solution. Thanks@ausyray, sorry but after my original post I added a recommendation for the Julius K9 harness available online but I would go to a pet store so that you can test fit to your dog and get the right size.
Sounds good and if you need more padding on the harness straps then get, or make, some seat belt shoulder cushions.That's ok. I spotted it. Just googled it, I was hoping her current ruffwear webmaster might do the trick. They look fairly similar (although the webmaster isn't crash tested) and it seems like it provides enough support. If I can get the load lashing point sorted again I think I have a winning solution. Thanks
HiHow big is your dog TeresaE?
