No, that’s my van. XtremeVan fitted it in 2017Hi, this looks exactly what I am after, do you fit them or is it a personal van?
Are you fitting rails just for show as Austops aren't rated to carry weight unfortunately... I'm down for an Austops in January don't fancy paying double for the convenience such as a jerba roofI have factory roof rails on my van that can go on the pop top when its fitted, how will that work with the wind out Fiamma, or will that not fit with rails still on? Also need the awning rail fitted to the other side of the van as I have two sliders.
Hi SPD,I had a skyline fitted and I'm very pleased with it.View attachment 1353
It's got a solar panel, roof rails and bars fitted too.
It lifts up quicker than an automatic Cali roof too. Maybe a little slower coming down ;-)
Quality is good on the Reimo Easyfit (providing the installer does it properly), I have a SWB with a basic foam mattress and solid bed board. You mention keeping the bedding in place, I’m pretty sure that isn’t possible on the Reimo. The basic mattress is thin (approx 20mm) and not that comfortable, I prefer to sleep down below.
I also queried the belt down securing but this is a pretty safe method, I’ve seen camlock and similar latches fail on boats and if that happens on a pop top roof it’s going to be disastrous.
Headroom is fine, we are both around 1.8m and no issues.
hi what roof is this it looks amazing? Is the van SWB or LWB?![]()
I reckon you should all go back and get refunds, they've all been fitted backwards!![]()
thanks for the help guys, I’m really liking the loom of the Reimo roof. I want to fit it with rear elevation for sure. I don’t know whether or not to go for the super flat or easyfit? I want as much height as I can inside and it looks like the superflat has higher lift hinges than the easyfit? Its really difficult to make this out in images but the superflat certainly looks to have more internal height?
This might be an obvious point but whether you want front or rear elevation completely depends on the internal layout of your van. Most classic side kitchen camper layouts go for front elevation (or the occasional side elevation!) whereas rear kitchen designs go for rear elevation. If it's not a camper, then I assume front elevation would be more popular as you get the height as you get into the side door or back from the front seats and the pop top bed is easier to access.
It’s a SWB and the roof is made for Westfalia by Reimo. As mentioned above, the roof orientation suits the rear kitchen layout best as you’ll see if you look at my review thread that @Ads_Essex linked above. I would say though that I also have standing height as soon as I’m in the side door too and the poptop bed is no more difficult to reach than a rear hinged roof so that isn’t a factor.hi what roof is this it looks amazing? Is the van SWB or LWB?
Easy to stop the fraying, run a very small bead of superglue along the end edge of the straps.The two front roof straps are straight forward but do fray over time which is annoying!
