Thank you @Big.mac and @Dellmassive for the pointers on this. Today my OEM retrofit kit arrived... now to suss out a sensible cabling route that doesn't destroy the interior and brave taking a drill to the tailgateI bought my OEM retrofit kit from EUcarsystems (link below). Service was great and it is installed and working as it should with the VW head unit. There are several different options available so be sure to select the right one (barn door/tailgate/LWB/SWB etc). I saw a few negative reviews of VAGTEC so i avoided them.
NEW VW T6 - Rear View Camera KIT - With Guidance Lines - Retrofit -
www.carsystems.eu
If he purchase a plug and play CanBus adapter to fit the Sony to the T6 there is a good chance the CanBus adapter has a reverse feed on it.. normally a purple wireHello T6forum,
due to I find no answer in german T6 cummunity I ask here.
A Friend of me bought a T6 Combi and bought Sony double DIN Radio with a Rear View Camera.
On VW Sharan (my car) a Fuse with Kl.15 give a switchted 12V signal to BCM
On which pin of the BCM is the input signal from the reverse gear switch?
Sorry for my not correct English.
With kind regards
Peter
That is true but if you don t have a relay in your tool box plus the ability to disable, then it will cause scratching headsIt won't flicker if you disable PWM or use additional relay
Dodged a bullet then! I almost bought from these guys but walked away when my product queries went unanswered.I would echo this, have had dealings with them and they are awful, they will lie to you and pretend to be in the UK etc etc, they are not, all they want is your money and they will not help if theres any issues
Same here arrived last week, yet to fit!Dodged a bullet then! I almost bought from these guys but walked away when my product queries went unanswered.
Went with CarSytems.eu. They’ve been great in communication. Camera due to arrive this week.
Mine has taken 3 weeks to arrive, so far. Had to pay £60 for import duty + fees.Same here arrived last week, yet to fit!
I seem to have managed to avoid that somehow?!Mine has taken 3 weeks to arrive, so far. Had to pay £60 for import duty + fees.
Did you get stung on the import costs as well?
What headunit do you have ?What about T6.1?
