Check the plastic protector isn't still on the lens! It happens.
Yep, I have done that.Check the plastic protector isn't still on the lens! It happens.
Sorry I haven’t replied yet. Haven’t been in the van in the light yet.Yep, I have done that.
I just need someone to tell me if this is the normal quality or I should take it back to the dealer please?
I have a 2019 Caravelle Exec and I know very little about car electrics but have just fitted an OEM wired rear-view camera. Cost me under £300 including the cost of an OBDEleven Pro for coding. Unless you are completely DIY incapable or do not have a few hours to spare give it a go yourself, your 3 hour round trip to to the 'specialist' would be just about enough time for a diy fitting. Can be done on your own but a second pair of hands to pull cables and detach lining would help.Hi all,
I'm after recommendations for a company to fit an OEM reversing camera to my '65 plate VW Caravelle (tailgate).
It currently has factory parking sensors and a discovery media mib2 headunit.
I live in High Wycombe.
I've contacted Absolut5 already but they're about 1.5hrs away so wondering if anyone has any recommendations closer to High Wycombe/slough/reading/Oxford?
Thanks in advance,
Nick
Cheers dellboy.I have a 2019 Caravelle Exec and I know very little about car electrics but have just fitted an OEM wired rear-view camera. Cost me under £300 including the cost of an OBDEleven Pro for coding. Unless you are completely DIY incapable or do not have a few hours to spare give it a go yourself, your 3 hour round trip to to the 'specialist' would be just about enough time for a diy fitting. Can be done on your own but a second pair of hands to pull cables and detach lining would help.
Why they fit them there, Such a daft place, we install them closet to the end of the number plate light trim, we have even installed a genuine Vw one thereOur new T6,1 arrived last week, I didnt know it had a reversing Cam we bought it from citygate as whatever spec they had ariving.
I would recomend not having the factory option , they have slapped the cam right in the middle of the barn doors it looks awful .
Apart from the position the image quality is cack , The ones Dav-Tec has fitted look a million times better .
Jeez, yeah that is a bit pap.Yep incredible,I guess it's easy .
I had a shock when I walked around the van and spotted it .
I had the exact same problem yesterday. Not got a solution yet. I thought there may be some sort of adaptor but can't find anything yet.
@5harpy You are in luck my friend, I have just today fitted an adapter I found after a good couple of hours of searching! It works a treat though will need some gentle persuasion to get on, in my case a dab of fairy liquid and a VERY light tap with a rubber mallet.I had the exact same problem yesterday. Not got a solution yet. I thought there may be some sort of adaptor but can't find anything yet.
Thank you. Ordered@5harpy You are in luck my friend, I have just today fitted an adapter I found after a good couple of hours of searching! It works a treat though will need some gentle persuasion to get on, in my case a dab of fairy liquid and a VERY light tap with a rubber mallet.
Steel-mate
Have a go at running it internally. I was kicking myself for not running the cable prior to conversion, but managed to run it back without too much trouble.Onto my next problem. A lack of foresight and forward planning means that having had the poptop done already, I now have no way to run the cable with the existing wires where they come through the tailgate.
I've fixed the rear camera internally for now but has anybody got any bright ideas on how I can route this cable from the outside?
