Wow does it. So actually I might be OK. Compared to a car that is still shocking, but I can handle that. Thanks for pointing that out. Might have a look for that now, haha.Manual says 1ltr to 2000km (1200miles is normal!)
Yep, it’s in the manual in the ‘filling the oil’ section. I guess it covers all engines too. They say it could be as much as a litre to a 1000km when the van is newWow does it. So actually I might be OK. Compared to a car that is still shocking, but I can handle that. Thanks for pointing that out. Might have a look for that now, haha.
We had an old Mazda 323 - the boxy saloon shaped one back in the day. Inherited it when my Grandad passed. Took it from Leicester to Scotland and it used all its oil (well, it used enough for the dipstick to not register oil). Thing was you’d never know- literally no symptoms. Not smoky, didn’t loose power, hardly got any warmer. Didn’t even get a warning light, you just had to check in the morning before setting off and keep oil in the boot. It kept running like that until we sold it for a Ford Mondeo (shudder).Wow does it. So actually I might be OK. Compared to a car that is still shocking, but I can handle that. Thanks for pointing that out. Might have a look for that now, haha.
Looking for some advice, have the CXEB 204, 2017, bought it from Lookers VW, it has full service history, a new dpf when I got it, then a few weeks after getting it the egr went on it, replaced under warranty, it had 43000 on it, now currently on 54000, I have noticed it does use a bit of oil. I have recently returned from a 450mile trip 300 of that towing a caravan about 1900kg and I topped up about 250ml of oil, checked the app see photo, does the 33% mean how full the dpf is? Have been told by the garage the turbo is passing oil a bit, just not sure if the turbo is the problem or the engine. Any advice would be much appreciated, I am about to do an oil analysis on it.Yes, CXEB - biTDI.
Yes, CXEB - biTDI.
VW say (in the manual) it’s normal to use 1ltr to 2000km driven. Regardless of this, the only way to know if it’s the engine I believe is with an oil analysis. A place called Millers does this in the UK. I think that would tell you if it’s engine wear or not.Looking for some advice, have the CXEB 204, 2017, bought it from Lookers VW, it has full service history, a new dpf when I got it, then a few weeks after getting it the egr went on it, replaced under warranty, it had 43000 on it, now currently on 54000, I have noticed it does use a bit of oil. I have recently returned from a 450mile trip 300 of that towing a caravan about 1900kg and I topped up about 250ml of oil, checked the app see photo, does the 33% mean how full the dpf is? Have been told by the garage the turbo is passing oil a bit, just not sure if the turbo is the problem or the engine. Any advice would be much appreciated, I am about to do an oil analysis on it.
The cxeb block and pistons etc were revised apparently in 2019.
So the assumption is if you have a later cxeb engine most likely from 2019 onwards then you should be okay.
But as we know the cxec engine come out in 2019.
As an example one of my buddies on here CZ mate ordered and paid for a 204PS van but when it actually arrived it was a 199PS van. So he's 2019 van has a cxec engine in it.
One guy on here actually swapped out the cxec long block into a cxeb engine fan.
He mentioned that most parts were exactly the same apart from injectors and inlet manifold and possibly the EGR as well.
I think he's LinkedIn above.
At the minute I'm having the engine replaced under the all-in warranty package from Volkswagen so all being well it's not going to cost me anything...... I was also worried about having the like for like fitted.
So I don't know whether I am going to get a revised cxeb engine or if I'm going to get a CX EC engine?
And I've also asked for a price for a new turbo, and I don't know if the turbos are exactly the same part number for a cxec and a cxeb engine?
Hi just following the threadNormal imho,
After running these vans is...
One oil top-up bottle (1ltr) midway between a long life service interval as per the dash display, which is 18,000miles on a long life schedule.
So, 1L per 18k miles.
Which is first service with new oil on 50% of dipstick,... Then midpoint 9k miles later dipstick at bottom so add 1L oil to take to top of dipstick, then 9k miles later next service due..... At which point the oil will be back to 50% oil level.
So assumed use of 1L per 18k miles.
Or
0.5L per 9k miles.
Wear limit is 0.5L per 1000km (621miles) - if you use less, your good.(According to VW)
If you use more you have a problem. It's either leaking via the turbo bearing or in cylinder via bore wear.
Extended warranty is no option in DK.Another patient joining the high oil use "club"
MY18 204hp CXEB
135000km
Oil weighing done by VW. Outcome is 0,7 liter/1000km.
Now anxiously awaiting kulance claim response from VW.
It's not thst simple.then you won’t have to pay anything.
Hi All,
We’ve been looking at transporters for quite some time now and have come across a high spec 2018 T32 BiTdi 204ps 4motion DSG transporter. It’s only done 8k miles total and had 1 owner since new. Full service history. Was fully prepared to go and put the money down but thought I’d do some last minute research on the engine. Obviously I’ve seen a lot of posts about EGR and Turbo failure and Bore wearing however a lot of these seem to be up nearer the 50k+ mileage region.
Main question would be should I be concerned with a such low mileage BiTdi or would I only really start to see problems after quite some time? Van would be used primarily for long runs to and from holiday destinations etc
Any help would be massively appreciated!
Van is just shy of £50k which on face value seems like a steal given it’s LWB, mileage and camper conversion but obviously an eye watering amount of money to shell out for what could be a ticking time bombI’ve recently bought a 6.1 with the newer biTDI CXEC engine and my understanding is VW fixed components would be 6.1 engine as they were paying so much out for warranty claims on the older one.
I personally have no issue with you are still engine I took out extended warranty for peace of mind and I know they say it has to use more than one piece of oil for 1000 miles to do anything about it regarding the older engine.
How much is the van being sold for?
8k miles? 6 years old and only 8,000 miles?Van is just shy of £50k which on face value seems like a steal given it’s LWB, mileage and camper conversion but obviously an eye watering amount of money to shell out for what could be a ticking time bomb
Suppose the argument would be with that budget, the options are endless really so why not shop for a more ‘reliable’ engine
My thoughts exactly when I first saw the posting. Seems the van was converted to a camper relatively soon after van was produced and I guess they didn’t use it much hence the sale. MOT history seems to indicate relatively little use over past years which again could be a concern potentially?8k miles? 6 years old and only 8,000 miles?
