Yes, CXEB - biTDI.is yours a CXEB EU6 204 BiTurbo?
there is also a thread for the CFCA 180 Bi-Turbo thread - 2016 180 Bi turbo CFCA engine failure is the EGR valve corrosion the cause of the scored and worn out bores
Del, add me to the lucky list.other 204ps members unaffected:
this could be due to the 2019 revisions? - (possibly the 2016-2018 range as there is a mention that the CXEB Block/Pistons etc was revised in 2019)
@Bigsidavies 2017 (135k miles so far)
@VanDamMan
@BoroBoy
Do you think the Ceratec made any noticeable difference to noise or fuel economy? I might put some in after my service next week.Del, add me to the lucky list.
2017 CXEB, 50K miles. Oil changes every 8-10k. Revo remap. Lots of mechanical sympathy, gentle warm up and turbo cool down. Often driven hard and/or towing. DPF & EGR delete. Added 1.5 tins of Liqui Moly Ceratec on last oil change after reading mentions on here. Negligible oil consumption.
What are your first impressions.Sorry to hear of your issues guys and keeping my fingers crossed for you Dellmassive.
Knowing about some of these issues, I have been really concerned since purchasing my CXEB EU6 204 BiTurbo 4Motion 2018 last December, now on 41,700mls
It went into RR yesterday for EGR blank/delete, DPF delete, Ad Blue delete. I am hoping this may save me some of these awful issues further down the road. I am low mileage user but will be monitoring the oil consumption carefully now and keeping a spreadsheet. At present I am not aware of any issues but will get an Oil Analysis done next few months and then a Compression Test. Will update with results.
1L per 1k and they call that a pass??? got to love VWI’m at about 1L every 1k, already had consumption test done by VW which it passed, it’ll be getting traded back in to them for a 150 soon
No smoke, no sound difference. Didn't notice anything different on the 110mile drive back from garage.What are your first impressions.
Particularly around anything that can be related to DPF, smoke, sound etc?
I can't see how doing this can't help.
Still not sure. The engine is always quieter after an oil change, so not sure how much may be due to the Ceratec and how much due just to new oil. At £20 a can, I thought I'd give it a try. Only did it a week ago. I'm still impressed as to how smooth the CXEB is anyway, I guess due to the balancer shafts.Do you think the Ceratec made any noticeable difference to noise or fuel economy? I might put some in after my service next week.
Is this TPI any use to those that no longer have extended warranty through VW? Seems there’s an admittance there but they’ll still happily take your cashI must admit @VanDamMan has been an advocate of the the gental warm up, switch off stop/start and allow to over run after a drive to allow things to settle.
Myself, with 50/50 split city/motorway driving i find myself 99% of the time switching the SS off..... So I now that is not a contribution factor.
Plus I always alow a gental warm up and cool down after a drive, and am always considerate of the engine and mechanicals. I dont tow or live in the Welsh valleys.
So tbh the van gets a fairy easy life.
Regular and full service only from VW and full warranty cover from day one.
Now I'm at 80k miles for 2018 6yr old van.
So I'm wasnt expecting any engine problems till at least 150k miles.
So makes sense that there is something else going on here.
And I'm glad VW had fessed up with the TPI for a known issue...from the new T6 engine in 2016 till the revision in 2019... That tells me that they was onto this right away. And fixed the problem in 2019.
But for us in the 2016-2019 age bracket we need to keep a close eye on things.... I'm just thankful we have, and have had the full warranty.from day one.
I can't imagine how upsetting it must be for people to be told by vw they need a new £20k engine... And even if they offered good will 50/50 it's still a big chunk of cash for a 6yr old van.
not sure. . .Is this TPI any use to those that no longer have extended warranty through VW? Seems there’s an admittance there but they’ll still happily take your cash
What year is yours?I think I’m heading the same way…started using about 800ml per 1000miles at moment. Van starting to feel sluggish - got a ‘dead spot’ around 1200rpm. Tried running some injector cleaner through but not sorted dead spot. Think I’ve prob got a few problems going on - high oil usage (engine or turbo) and possibly DMF.
Caravelle 2.0 204 BiTDI standard no remap etc. 93500miles.
Unsure where to go next - might reach out to Darkside Developments and let them have it to diagnose what’s wrong etc. Any pointers of what I could check myself or is this a case of let a garage have it …?
