Ad-blue MFD not displaying
If the seller knows the Adblue is mapped out and fails to mention it, or else misrepresents the truth when asked, that would be a criminal act of fraud.
But then it's likely that if they were honest and did mention it 95% of buyers would regard it as a plus point.
Personally I would not go near one. Not because I've any ideological objections to an adblue delete (I don't), but its a sign that someone couldn't afford to maintain or repair the vehicle properly so where else might they have taken a shortcut in the name of saving pennies?
I did actually have a car with it but that came my way via an elderley relative as a freebie so such concerns weren't pertinent.
What is also concerning is that any potential new owner might be left with the mess, inconvenience and expense of rectifying the misdemeanour. I have no idea if any removal or deletion might be criminal offence or not but it would be unjust if the onus was passed on to a new owner to prove innocence.
So there’s more than one model of Startline cluster? I’ve not come across that before.
Apparently, I helped a member on here with advice on fitting a MFSW and when he was getting it coded In I mentioned getting the big digital MPH done at the same time.
He tried and it wasn’t possible. He sent me pics of his cluster and it was different to mine.
I will try find the pics.
Here they are.
One has the digital petrol gauge the other has the separate wee dial.
It’s the digital gauge one that you can’t get the big digital MPH on.
I wonder if it only displays when it gets down to 1500 miles & comes up as a warning rather than a selectable display.
That’s what my van does - 2017 Startline. It states number of miles (can’t recall exact number - possibly 1500) and an amount of Adblue required.
Can’t see anything about Adblue on the display other than that (I’ve a MFSW fitted)
The one at the top with the physical fuel level dial is what I thought was termed Highline clocks. The lower one is what I had on my Startline and I can confirm big mph not possible.
Nope it’s the top one I got on my startline T6.
I notice the bottom one is the exact same as the cluster in my T5.1 works van. Also a startline
So you don’t see anything about the ad blue on the mfd until it drops to 1500 miles left?
Then a prompt pops up on the mfd?
I've got the same clocks, albeit 6.1, and the display shows me the AdBlue mileage remaining, currently 17,000 odd miles.
Correct
Like I said can’t recall the exact miles when the message appears but could well be 1500, along with a figure for amount of adblue. It’s happened twice since I’ve had the van in about 8000 miles.
If I scroll through the mfd I can’t find any other reference to adblue other than when that message pops up with the warning light
Correct
Spot on thanks
Mine’s a very early T6 Startline that does share some parts with the 5.1.
Interesting.
It’s @Tanstalf on here who has had problems with the earlier cluster and activating ccs.
But his is a 2017 and I think it’s EURO5.
Mines is 2018 EURO6 with the later cluster.
I had no problem activating ccs and getting the big digital MPH.
Have you activated ccs on your EURO5 ?
I activated cruise control, yes. I’m learning more by the day here cos I didn’t think there were any 2017 EUR5s either!
Is there a thread about @Tanstalf’s issue?
Found it. From the looks of it @Tanstalf is taking the harder route of CCS on the wheel with a EUR5. Mine’s on the stalks.
Was it still taking a cable into the bottom black and purple plug in the e box to activate ccs ?
I don’t think @Tanstalf got his ccs working and now think it’s something to do with the earlier clocks or something to do with it being a EURO5
Yes it involved the connections to BCM and that horrible one down at the bottom of the compartment under the battery. Probably the worst job ever, that connector.
Well, mine had the lowest of the low clocks and is def a EUR5. @Dav-Tec advised me (very well, I might add) that wheel CCS not possible on the EUR5 so I went for stalks. Not looked back.
EU5 engine don't accept CCS on the wheel and you'd need to upgrade your clocks if you want ACC. From speaking with other industry experts in various fields some include a VOSA technical specialist flashing firmware on for ACC and the current process involved means using software that hasn't got VOSA type approval and the ECU software is a grey area both of these I've mentioned before, it has certain legal implications and it's information I'm putting out there it's up to you guys what you do with it.
Option three is the option we would offer using a CCS non trip stalk and trip/media controls on the wheel this is how it would of been from factory too.
Just my 10p worth
Chris
Thanks guys for digging into this problem again. At the moment I need to fix a power (no horn) issue, but happy to try any resolution provided.
It is indeed a 2017 EURO5 T28, with older clocks. No BIG MPH for me and the new MFSW only provides the basic media controls.
Will add some photos later.
