MFD display...
Adblue in Ltrs.... not Gallons.
Took me a min too.....
Ahh!MFD display...
Same hereThe only way I’ve found to do it is to switch the units in the MFD.
Errr! Because you choose to have your consumption displayed in MPG & not L/100km. At least you have the choiceWhy is metric pushed down our throats but adblue is imperial? Same on my Volvo. Is it a US thing?
Is this what I have done.I thought it was displayed in gallons because I had to change to Australia in the settings to get the large MPH in the MFD display.. I therefore just converted the 2.5 gal to litres (using Aus gallons not uk), which was about 10 litres, which was handy as that was the size I had brought.
ShhhPretty sure they use litres in Aus, not gallons, but there are several Aussies on here who can clear this up for us.
I normally knock a couple of litres off what the dash says.
Fill whatever volume you like.Sorry for the resurection but I need to top up. I'm a little scared too as its first time and I have been told you can over fill. If I use a forecourt pump and wait until it clicks off, will that over fill the tank?
This fake stories about overfilling Adblue must stop eventually.
EDIT:
Who told you that you can overfill?
YesSorry for the resurection but I need to top up. I'm a little scared too as its first time and I have been told you can over fill. If I use a forecourt pump and wait until it clicks off, will that over fill the tank?
But isn't it actually a cunning way to lay the blame on the customer...Fill whatever volume you like.
EDIT:
