@Absolut5 I had 13cm pioneers fitted as part of my camper conversion and when the fader was coded you can hear that they are noticeably quieter than the front and don’t sound great. I don’t know the model but do you think putting higher end pioneer speakers of the same size in would help or could there be an issue with the wiring?
I did a quick search on 13cm speakers and Rockford fosgate seem to be highly rated.
They do get louder when I sit closerThey will be quieter, distance, size
If you want them to play louder, Look for speakers that are efficient like the Blams, most of them run 2 ohm coils which make them run high sensitivity values unlike 95% of speakers that run the standard 4 ohm rating
I guess it comes down to what you want these speakers for. I’m not sure I’ve worked that out yet!
Thanks for the advise on the Blams, just had a quick look and I see they do a 5x7 so I might see if these will fit. Have you used those before? Used to swear by 6x9s as a teenager, really good sound and don’t need a sub
The speakers are fitted near the rear doors. I went for small ones due to the depth.@cy294, I wonder where do you have fitted your rear speakers? any pics? thx
Does anybody know what iso pins I need to add rear speakers to van
Hi Michael,Hi Chris, how did you get on with speaker situation,I’m going through probably the same issues.
My T6 goes into conversation end of May.
Regards
Michael
What pins were these? I can't see anything on the post but i might be being blindHi Michael,
I just ran cables to back off van then added them into the harness with the pins highlighted below,
Monkton thing is I need to get the fader activated
