Just seen your post and you got me rather worried (I have a T32 and just ordered the falkens) so I double checked.....
Falken Wildpeak AT3WA have a 108 load rating, needless to say there was a big sigh of relief!
Yes definitely 108 load rating, 235 65 17, I’m about to order a set for winter, I’m just deciding what wheels to put them on
They have a new version of this tyre but reports are it’s a different compound and not so good on snow and ice, so buying the AT3s while still available
245/65 R17 AT3WA's are 111 rated so that's also a factor, they'll be slightly stiffer than a 108 rated tyre so possibly a bit less comfort. But also stronger?
Hi. I was looking at 225/65 r17s, as my Kombi is lowered.
The AT3 Wildpeaks of that size are only 102 rated.
Hence I went for Avon AX7s
I didn’t want to go as big as 235/65 r17s in case of rubbing/under-reading of speedo or ‘looking’ wrong.
The 225/65 r17s also have an almost identical diameter/rolling radius as the 265/45 19s I intend to fit into my 19x9 Summer wheels
These are so much a Chinese BF Goodrich KO2 knock-off :rofl: Not sure if that's a good thing or not! They're the Comforser Cf1100. They're about half the price of a KO2, £110 for a 225/65R17 Vs £220 for a KO2 of the same size. Speed and load rated too, 102T for the 225/65.
I have 265/60/18 cf1100 on mine and they just rub on a hard full lock just on the very outside of the mud flaps it's so fine you can only see it when they are muddy but thinking might put 235/60 on the front and move the others to the rear
