Are these codes a concern? (Potential van purchase)
sipep
Hi all.
Just been to view a stunning t6. Low mileage (23k). The owner has replaced with a brand new DSG combi. From what I can see is a second / third van owned from new , that is not getting used (3 other posh motors on the drive).
No issues on my test drive. I asked if I could plug in my obd eleven, which he was happy with.
It's come up with a few stored fault codes. I've cleared them and it retained a "low voltage" code. He mentioned it did have a flat battery as a result of using the radio and heater when cleaning it last week and used a battery pack to get it going.
I do think it's a genuine van, and just wondering if some of the fault codes will be related to the battery. I'll post some images
Would be more legible if you could post history logs of the vehicle. They were stored when the vehicle was scanned and are now available off-line.
OBDeleven > Garage > Select the vehicle > History > Tap the envelope symbol ✉︎ on top right > Email the history log to yourself.
Hi. Thank you. I've never used it before.
Code:
OBDeleven vehicle history log
Date: 2023-08-18 19:30
    VIN: WV1ZZZ7HZKH190042
    Car: Volkswagen Transporter
    Year: 2019
    Body type: VAN
    Engine: CXHA
    Mileage: 35050 KM
Code:
Full scan
    Control Units: 12
    Fault count: 1
    Control Units:
        61 Battery Regulation
        System description: Batt.regelung
        Software number: 7E0907534
        Software version: 0762
        Hardware number: 7E0937090D
        Hardware version: H82
        Serial number: 8602 245190035
        Faults:
                No trouble codes found
        5F Multimedia
        System description: MU-E-D-ER
        Software number: 1K8035150L
        Software version: 7205
        Hardware number: 1K8035150L
        Hardware version: 070
        Serial number: 22081900010171
        ODX name: EV_MUEnt4CGen2LGE
        ODX version: 001032
        Faults:
        25 Immobilizer
        System description: IMMO
        Software number: 5K0953234
        Software version: 2050
        Hardware number: 5K0953234
        Hardware version: H03
        ODX name: EV_Immo_UDS_VDD_RM09
        ODX version: A03710
        Faults:
        19 Gateway
        System description: GW-K-CAN TP20
        Software number: 7E0909901
        Faults:
        17 Dashboard
        System description: KOMBI
        Software number: 7E0920971A
        Hardware number: 7E0920971A
        Serial number: 00000000000000
        ODX name: EV_Kombi_UDS_VDD_RM09
        ODX version: A05736
        Faults:
        13 Adaptive Cruise Control
        System description: ACC Bosch PQx
        Software number: 7N0907572C
        Software version: 0211
        Hardware number: 7E0907572
        Serial number: 0709190453B4FD
        ODX name: EV_ACCBEGVW361
        ODX version: 001006
        Faults:
        10 Parking Assistance
        System description: PARKHILFE 4K
        Software number: 7E0919475T
        Software version: 0212
        Hardware number: 1Q0919475
        Serial number: 32931914201999
        ODX name: EV_VW75XParkAssis4K
        ODX version: 001013
        Faults:
        09 Central Electrics
        System description: BCM PQ25 Max4
        Software number: 7E0937090D
        Faults:
                04194 - Vehicle status with insufficient voltage Lower limit not reached
                    static
        08 Air Conditioning
        System description: Climatic-T5
        Software number: 7E0907047AK
        Software version: 0708
        Hardware number: 7E0907047AK
        Hardware version: H23
        ODX name: EV_ClimaticT5
        ODX version: A01003
        Faults:
        03 Brakes
        System description: ESC
        Software number: 7E0907379P
        Software version: 0133
        Hardware number: 7E0907379M
        Hardware version: H06
        Serial number: 62499000002360
        ODX name: EV_Brake1ESCCONTIVN75XGP2
        ODX version: 011001
        Faults:
        01 Engine
        System description: R4 2.0l TDI
        Software number: 04L906056RJ
        Software version: 6749
        Hardware number: 04L907445
        Hardware version: H02
        ODX name: EV_ECM20TDI03004L906056RJ
        ODX version: 004002
        Faults:
    Mileage: 35050 km
    Date: 2023-08-18 16:33
Code:
Full scan
    Control Units: 12
    Fault count: 32
    Control Units:
        Faults:
        5F Multimedia
        ODX version: 001032
        Faults:
                U101100 - Supply voltage Voltage too low
                    Intermittent
                U140000 - Function restriction due to insufficient voltage
                    Intermittent
        25 Immobilizer
        ODX version: A03710
        Faults:
        19 Gateway
        Faults:
        17 Dashboard
        ODX version: A05736
        Faults:
                    Intermittent
        15 Airbag
        System description: VW10Airbag021
        Software number: 7E0959655J
        Software version: 0018
        Hardware number: 7E0959655J
        Hardware version: 010
        Serial number: 003EK005ZL9L
        ODX name: EV_AirbaVW10BPAVW12X
        ODX version: 001028
        Faults:
                B13BCF2 - Multiple collision brake No function
                    Intermittent
        ODX version: 001006
        Faults:
                    Intermittent
                    Intermittent
        ODX version: 001013
        Faults:
                    Intermittent
                    Intermittent
        Faults:
                03301 - Return message regarding driver door closing condition Implausible signal
                    Intermittent
                03303 - Return message for left rear door closing condition Implausible signal
                    Intermittent
                00532 - Supply voltage Lower limit not reached
                    Intermittent
                00446 - Function limitation due to insufficient voltage Lower limit not reached
                    Intermittent
                    static
        08 Air Conditioning
        ODX version: A01003
        Faults:
        03 Brakes
        ODX version: 011001
        Faults:
                    Intermittent
        01 Engine
        ODX version: 004002
        Faults:
                U029D00 - Lost Communication With NOx Sensor "A"
                    Intermittent
                P24C700 - Particulate Matter Sensor Temperature Circuit Range/performance
                    Intermittent
                P023600 - Turbocharger Boost Sensor (A) Circ. Range/Performance
                    Intermittent
                P023800 - Turbocharger Boost Sensor (A) Circ. High Input
                    Intermittent
                P023700 - Turbocharger Boost Sensor (A) Circ. Low Input
                    Intermittent
                P010500 - Manifolt Absolut Pressure/Barometic Pressure Circuit
                    Intermittent
                P019300 - Fuel Rail Pressure Sensor "A" Circuit High Input
                    Intermittent
                P019100 - Fuel Rail Pressure Sensor "A" Circuit Range/Performance
                    Intermittent
                P056200 - System Voltage Low Voltage
                    Intermittent
                U041600 - Invalid Data Received From Vehicle Dynamics Control Module
                    Intermittent
                P064100 - Sensor Reference Voltage "A"                   Circuit Open
                    Intermittent
                P065100 - Sensor Reference Voltage "B" Circuit            Open
                    Intermittent
                P069700 - Sensor Reference Voltage "C" Circuit Open
                    Intermittent
                P06A300 - Sensor Reference Voltage "D" Circuit/Open
                    Intermittent
                P06A600 - Sensor Reference Voltage "A" Circuit Range/Performance
                    Intermittent
                U041500 - Invalid Data Received From Anti-Lock Brake System Control Module
                    Intermittent
                P050200 - Vehicle Speed Sensor "A" Circuit Low Input
                    Intermittent
                    Intermittent
    Mileage: 35050 km
    Date: 2023-08-18 16:18
Code:
Full scan
    Control Units: 12
    Fault count: 32
    Control Units:
        Faults:
        5F Multimedia
        ODX version: 001032
        Faults:
                    Intermittent
                    Intermittent
        25 Immobilizer
        ODX version: A03710
        Faults:
        19 Gateway
        Faults:
        17 Dashboard
        ODX version: A05736
        Faults:
                    Intermittent
        15 Airbag
        ODX version: 001028
        Faults:
                    Intermittent
        ODX version: 001006
        Faults:
                    Intermittent
                    Intermittent
        ODX version: 001013
        Faults:
                    Intermittent
                    Intermittent
        Faults:
                    Intermittent
                    Intermittent
                    Intermittent
                    Intermittent
                    static
        08 Air Conditioning
        ODX version: A01003
        Faults:
        03 Brakes
        ODX version: 011001
        Faults:
                    Intermittent
        01 Engine
        ODX version: 004002
        Faults:
                    Intermittent
                    Intermittent
                    Intermittent
                    Intermittent
                    Intermittent
                    Intermittent
                    Intermittent
                    Intermittent
                    Intermittent
                    Intermittent
                    Intermittent
                    Intermittent
                    Intermittent
                    Intermittent
                    Intermittent
                    Intermittent
                    Intermittent
                    Intermittent
    Mileage: 35050 km
    Date: 2023-08-18 16:10
Reactions: mmi
Looks like I did 3 X scans, the one being after I cleared the faults
I've just try to clean up my opening thread message so it makes about more sense
Reactions: mmi
Probably battery, especially taking into acount what you've been told by the owner.
If you wanted to be 100% you could get a battery from Euro and stick it on the van before parting with any cash. If you still have doubts after that then walk away and return the battery to Euro for a refund.
The owner is putting a full MOT on the van for me Monday and putting the battery on a trickle charger. Any vcd / odbeleven gurus able to comment on the above?
Hi all.
What flavour van is it @sipep ?
The original Moll battery had a habit of dying fairly early on and being replaced free of charge by VW bless them.
Reluctance starting with the stop/start not activating being a bit of a precursor.
Yeah, euro 6, I think only the very early t6s (2016) were euro 5, but this can very as late 2016s can be euro 6
