Not that I know of other than cheaper knock off copies.Question is there anything better out there that people are using instead of the Ghost system?
What facts do you base that on?Not that I know of other than cheaper knock off copies.
But, as discussed above, removing the power from the OBDII socket doesnt disable it, it just means the thief needs a powered device which he'd probably be using anyway. Surely you be better switching canhigh/canlow or moving those pins and making up an adapter that corrects the swap?
How log does the stop start module take to do the button press? Could that not be included as the first button in your code, then you could wait for it then enter the rest? Just a thought.Should be fine. The only thing I have found That interferes with the code entering is my stop start memory module. As that is on the same canbus as the ghost and if I don’t get my code in quick enough it of course simulates a button press to disable start stop and that can be seen as one of the code buttons you’re trying to input.
Never had any issues using mine on two different motors with auto lights, wipers etc. You'll be fine.I am finally getting round to getting ghost fitted.
Does anyone know if leaving lights in auto out of auto, windscreen wipers in or out of auto and fan on or off will affect operation of ghost on starting.
1 to 2 seconds and normally just after the needle sweep has completed. Yes, you could incorporate that button in your code, in which case you wouldn't need the SS memory module as you would always press it.How log does the stop start module take to do the button press? Could that not be included as the first button in your code, then you could wait for it then enter the rest? Just a thought.
It's booked in and yes will sleep easier.Hi Grainfoot, should not be a problem - regularly leave the auto lights on auto fan on etc. and all is good - go ahead get it fitted and sleep a little easier!
