That's intriguing! I guess the status was "Intermittent, Not confirmed" again in scan A2?OK, I think we're getting a little bit closer with this test. Here are two sequences that result in four scans:
IGN on, clear, scanA1, IGN off, key out, IGN on, scanA2
later...
IGN on, clear, scanA3, crank, scanA4, engine off
A1: 01-Engine -- Status: OK 0000
A2: 01-Engine -- Status: Malfunction 0010
A3: 01-Engine -- Status: OK 0000
A4: 01-Engine -- Status: OK 0000
So I'm pretty confident that those test prove that it's the initiation of the system (IGN on) where the fault is present, and cranking has nothing to do with it. This marries with observed reality - it starts every time.
Some differences though:The vehicle referred-to in the Ross-Tech link above turns out to be a Golf GTI from 2016 - same manufacturer and year as mine.
Yes that's right, see code snippet below from scanA2. Good spot @mmi - so do you think that means that it tested more than once in the initialisation?That's intriguing! I guess the status was "Intermittent, Not confirmed" again in scan A2?
5273 - Output for Starter Relay
P0616 00 [036] - Short to Ground
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 260697 km
Date: 2023.10.03
Time: 18:02:13
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 67 °C
Intake air temperature: 23 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.280 V
Unlearning counter according OBD: 40
Starter control: terminal 50 feedback-Bits 0-7: 0
Starter control: relay 1-Bits 0-7: 0
Starter control: release conditions-Bits 0-7: 2
Starter control: release conditions-Bits 0-7: 86
Starter control: shut-off conditions 1-Bits 0-7: 0
Number of manual engine starts-Bits 0-7: 0
Number of manual engine starts-Bits 0-7: 44
Number of automatic engine starts-Bits 0-7: 0
Number of automatic engine starts-Bits 0-7: 54
Number of automatic engine starts-Bits 0-7: 212
5459 - Control Circuit for Starter Relay 2
P3048 00 [036] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 260697 km
Date: 2023.10.03
Time: 18:02:13
Definitely differences but the guy owned it for a while before it his EML came on, perhaps it was there in the background? My EML has never been on, but the fault is showing as intermittent.Some differences though
I had a thought about the intermittent status: if the fault only occurs when initialising, then all those stop/start cycles would be counted as well as starts from cold. That might appear as 'intermittent' when in reality it is always a fault on cold start, and never a fault on SS.That's intriguing! I guess the status was "Intermittent, Not confirmed" again in scan A2?
That leaves me thinking that it's either an ECU initialisation routine that is going wrong somehow, or maybe leading us back to what we all have suspected at one point or another, that there's a foreign device in the starter circuit somewhere that saps power when the IGN is first switched on, but then becomes invisible once it has powered-up properly. Could be a tracker or immobiliser box somewhere in the dash, which is the only place I haven't looked.
Hmmm. I'll do a scan for adaptations on module 1.Could be even a coding mistake of something if the fleet had for example speed limiter coded in?
Ah OK. Hmmmm.Different ECU manufacturer (Continental vs. Bosch)
Also, you know, I wonder if we would naturally expect to 'Control Circuit for Starter Relay 2' errors if there's any fault in the circuit, and that fault in this case is 'Output for Starter Relay - Short to Ground' - in other words it's one fault that triggers another. If that's the case, we can probably narrow it down to a single wire that goes from ignition switch > fuse SC23 > Starter Relay 2.
;SW:03L-906-019-GQ HW:03L-907-309-L --- Engine
;Component:R4 2,0L EDC H38 8440, Coding:01194012230401080000
;EV_ECM20TDI01103L906019GQ,003006,EV_ECM20TDI01103L906019FH_003.rod
;Tuesday,03,October,2023,20:58:29:49191
;VCDS Version: Release 23.3.1 (x64) Data version: 20230421 DS346.2
;VCID: 00587C6A5A8F017A0FB-8054
IDE00259-Idle RPM correction,0.0 /min,2
IDE00263-Injector 1 correction value,BAAEB1H ,7
IDE00264-Injector 2 correction value,AZ1GBSH ,7
IDE00265-Injector 3 correction value,ARIIBIH ,7
IDE00266-Injector 4 correction value,A1IWDAH ,7
IDE00275-Particle filter initialization,0 Tkm,2
IDE01637-Service regeneration of particulate filter while driving,0 ,1
IDE01711-Blocking of particle filter regeneration,not active ,1
IDE02247-Static maximum speed limit,300.0 km/h,2
IDE02248-Individually adjustable top speed limit,300.0 km/h,2
IDE02632-MAS00478-Activation of static maximum speed limit-Reserved,0 ,1
IDE02632-Activation of static maximum speed limit-,OFF ,1
IDE02633-Deactivation of static maximum speed limit,00 00 ,2
IDE04158-Activation of start/stop function,active ,1
Elapsed Time: 00:03
I believe the only thing we can conclude from "Intermittent, Not confirmed" is that the fault have happened (at least) once and the fault was not active when scanned.so do you think that means that it tested more than once in the initialisation?
I'm fairly confident that the ECU registers a fault only once in ignition cycle (frequency in freeze frame data) - if true also here it could possibly mask subsequent events after (supposed) initialisation event.I had a thought about the intermittent status: if the fault only occurs when initialising, then all those stop/start cycles would be counted as well as starts from cold. That might appear as 'intermittent' when in reality it is always a fault on cold start, and never a fault on SS.
Does that theory hold water?
Seems to be identical with other scans of similar vehicles - just known variations: cruise control, etc.coding
Agreed.Pretty wild speculation though, we don’t know how accurate fault labels really are.
ExactlyI can isolate my solar panel, so I assume that I’d remove the neg from the LB, then neg then live from starter, and connect the starter wires together through an old headlight bulb?
It's another amazing detective story, we just can't cheat and turn to the back page to see whodunnit...The plot thickens![]()
if I hear ticking I will RUN.It’s fused! Don’t cut the red wire!
